How big of an air compressor do you need?
Subscribe
Jul 6, 2009 | 02:00 AM
Im curious, how big (gallon wise) of an air compressor do you need to paint a car body? Ive seen pics on here with people painting there 3rd gen in there garage. Ive been wanting to get one... Would anybody know?
thanks!
Reply 0
Jul 6, 2009 | 02:26 AM
Re: How big of an air compressor do you need?
25-30 gal
what you need is a good size tank or fast compressor to hold it at the pre-set PSI
Reply 0
Jul 6, 2009 | 12:48 PM
Really just get the most air you can afford and you should be pretty happy. I would say 80 gallon i know that sounds huge but it is so worth it if you buy a quality compressor. I had a 60 gallon single stage and it just couldn't keep up with anything and i spent over $500 on the damn thing. I now have a 2 stage porter cable C7750 and it rocks! pretty reasonable on amazon too. Really for painting a car with all the sanding and the amount of air that air tools now seem to demand i would go with a good two stage pump and about an 80 gallon tank. you could probably get away with a 60 gallon if you wanted to do the work all by yourself with out help. which by the way sucks. The bigger the better
Reply 0
Jul 10, 2009 | 11:45 AM
Also CFM rating is very important. You need a compressor that rated AT LEAST the minimum CFM requirement by the paint gun. For example, my paint gun DeVilbiss requires 12.5 CFM @ 23PSI, and my compressor is rated 15 CFM @45 PSI (the lower PSI, the higher CFM). you can get by a small compressor, but you have to wait for the compressor to fill up.
do not forget to buy a water/ oil filter
Reply 0
Jul 10, 2009 | 12:27 PM
I own a bodyshop and we use a 7.5 hp 28 cfm @175psi 80 gal unit. You don't need one that big to paint a car. When I started out I had a 3.5hp 30 gal sears air comp that did the job just find as long as I made sure the inlet filters were clean and one tool at a time was used. That one cost me $160.
Reply 0
Subscribe
