removal of rear tail light
Old Jul 8, 2009 | 09:59 AM
SSZ2891's Avatar
whats the easiest way to remove my cracked passenger side tail light.
Old Jul 8, 2009 | 10:33 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: removal of rear tail light
Everything has to be removed fom inside the rear hatch.
Old Jul 8, 2009 | 10:46 AM
mikeiaz's Avatar
You do not say if it is a Camaro or a Firebird - here is how for Camaro -You will need to remove the plastic trim panels in the rear - the one at the very back that the hatch latches into) just a few screws, and both side trims (don't know if you have the molded side trims or the carpeted panels), and if I recall correctly you also need to take out the spare. Then you should be able to see the back side studs of the taillights - just unscrew by hand, I think it is about 5 per light - I think you also need to remove your license plate mounting, easy just a couple bolts. Now you should be able to pull your taillight out from the exterior, it will move out a few inches and then you can reach benind it to twist out each of the bulbs/connectors - that's it. Took me about 20 minutes when I did mine and I started with no clue so it can't be that hard!
Old Jul 8, 2009 | 11:00 AM
SSZ2891's Avatar
i got all the screws out and its wiggling around the tailight itself but how do i get it completely out of the car
Frozer!!!
Jan 19, 2024 04:55 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
