hood pins with hinges?
Old Jul 14, 2009 | 12:47 AM
GQ1337's Avatar
Car: 89 Camaro RS
Hey guys i'm a newbie to thread posting here, i was wondering if theres anyway that my recently purchased fiberglass cowl hood that is setup for hinge and latch application can use hood pins and the hinges without the latch.. or does hinges cause the hood to angle down too much and would cause an oblong hole for the hoodpins...i hope that makes sense lol. Thanks guys.
Old Jul 14, 2009 | 02:25 PM
1Aauto's Avatar
Former Sponsor
Re: hood pins with hinges?
Welcome to the site.You can pin the front of the hood and remove the latch from it if you wish to.
Buy a good set of hood pins, the parts store ones are cheap and rust out.
Old Jul 14, 2009 | 02:36 PM
Stephen's Avatar
Car: 87 GTA
Some aftermarket hoods (most bolt ons) are designed to use the stock hinges & stock latch.
Hood pins are primarily for a pin-on only hood, for looks, or for those that don't trust the aftermarket hoods to stay together without pins.
Old Jul 14, 2009 | 03:16 PM
1Aauto's Avatar
Former Sponsor
If you run a fiberglass hood even if it retains the factory latching mechanism,I strongly recommend pinning it.
It's allot safer and cheaper than fixing a busted hood,cowl,windshield & roof because the hood popped up. I see it happen all the time.
Old Jul 14, 2009 | 03:23 PM
ian1320's Avatar
Car: 88 IROC-Z and 86 IROC-Z
Engine: TPI 305 and E85/Nitrous 383
Transmission: 700R4 and T56
Axle/Gears: 3:27 and TBA
My 85 IROC has hinges and hood pins, and the holes are not oblong. My hood is stock steel though so maybe my application doesnt apply.
Old Jul 14, 2009 | 04:01 PM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
i have a fiberglass hood and have it a totall pin on.. i did have the front pined and the rear on hinges but i forgot to lock the pins one night and it ripped off... lucky it didnt hit the car or break.. it landed bottom down in the road behind me at 2am so noone was on the road. lucky me.. it could have been a lot worse. as long as u measure right u can drill the holes right.. start out with a small bit and make sure ur all lined up and then use the bigger drill bit to drill the hole for the pin.. shouldnt take u more then 30 min to install
Old Jul 15, 2009 | 02:43 AM
GQ1337's Avatar
Car: 89 Camaro RS
Yea being fiberglass i dont want to take any chances lol. No horror stories for me. I appreciate all the responses guys thanks=)
Oh and Tony i have used 1A Auto in the past for my interior restore, i think i got my carpet from you guys:P
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
chuck13
Interior Parts Wanted
Sep 22, 2015 11:19 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
