Door Removal
Old Jul 25, 2009 | 05:30 PM
91CAMARO GUY's Avatar
Car: 91 camaro rs
Door Removal
How do you remove the drivers side door from the body and the door from the lower hinge?
Old Jul 25, 2009 | 05:41 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Re: Door Removal
first, you need to take your door panel off, then disconnect the wires for window, door etc.
the upper hinge has 3 bolts on the outside (13 mm)
the lower hinge has 1 bolt from the outside (13mm) , and 2 bolts from inside behind the kick panel (15 mm I believe)
you need someone to help you when you remove the door because the door is too damn heavy
Old Jul 25, 2009 | 05:46 PM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Re: Door Removal
for the lower hinge on the driver side, the bolts from the inside are behind the hood release. There is a silver box (window relay) needs to be removed in order to access the bolt.
Old Jul 25, 2009 | 06:02 PM
Car: 91 camaro rs
Re: Door Removal
Old Jul 25, 2009 | 09:14 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
Re: Door Removal
You also might want to consider removing the fender first. You don't have to but it will make the job a little easier.
Old Jul 28, 2009 | 06:14 PM
Net-Viper X's Avatar
Car: 91 Bird w/Aero Pkg - 02 T/A Col Ed.
Engine: 5.0L - 5.7L Ram Air
Re: Door Removal
Thats a very wise suggestion, not only does it allow easy access to the bolts on the upper hinge, but it will prevent damage to the edge of the fender. Soon as that last bolt comes out, the door is gonna slip a bit, and wreck the paint along the rear edge of the fender and possibly the door too.
ktthecarguy
Jul 5, 2020 11:46 AM
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
3rdgenparts
Aug 8, 2015 07:09 PM
