Door Lock/Latch Problem
Old Jul 27, 2009 | 06:32 PM
T1m3_Sh1ft3r's Avatar
Car: 1986 Trans Am
Transmission: TH700R4
Axle/Gears: IDK yet
Hey yall, well this time i think i really hosed up big, a few weeks ago i was working on my firebird, and well i herd a clang and the door opened all the way, well i tried to close the door, but noticed that the latch was closed, so i had to use a log to close the door(propping it the log between the ground and door) well i opened it the next day and fiddled with the latch and the two rods that goto the latch push or pull they didn't do anything i tried the key and nothing, so i took the latch out and noticed that i just needed to pry the thing that locks the latch up, i figured it was fix and closed the door. well i guess i didnt fix it so the only way to get into the firebird is though the t-tops. so my question is is there a way short using a crowbar or damaging the door to open the door? please tell me there is a way, i would het a better picture but i cant get the pass door open either, should i just weild the dore shut and take the window out? act out some duke boys?
Attached Thumbnails Door Lock/Latch Problem-door-lock.jpg
Old Jul 27, 2009 | 07:23 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Re: Door Lock/Latch Problem
Hold on a second here, how did you get it closed? Did you just slam it closed? When you put it back together did you check to make sure the connecting rods where hooked up tight? Sounds like the rods are not connected or your latch is broken (and not repairable). I'm fairly certain you should be able to get a coat hanger and pull the latch up and release the door. If you can't do it a locksmith can. I'd say just replace the latch(s).
Alex
1992 Trans Am
May 10, 2023 07:19 PM
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
86IROC112
Apr 9, 2016 10:20 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
