Fixed a gap nicely.
Old Aug 1, 2009 | 10:32 PM
resinlake's Avatar
Car: 2011 6.2 Silverado, 88/85 camaro
Fixed a gap nicely.
Well, I had the dreaded gap in between the top of my front bumper cover and my hood.
started adding washers under the bumper cover lip and would close the hood till there was no gap. I drilled 4 holes along the front down through the head light bar, trying not to crack the fiberglass. I cut 4 - 6" lengths of all thread rod, and dropped each piece down through a stack of washers (10 washers) I put a nut on the top and one nut on the bottom of each stack.
This worked great, and it is fixed in place. I can take a picture if anyone really wants to see it. Also, if any of you ever crack your light bar, here is a great way to fix it. Buy a box of that Bondo fiberglass repair. I cut a length of fiberglass mesh, mixed up some resin and hardener, dipped it in, wrapped it around where I need to, brushed on some more resin and now its like the piece never broke off, good as new, very strong.
Old Aug 1, 2009 | 10:36 PM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
Re: Fixed a gap nicely.
yeah i did the same thing with the washers under that front lip. worked perfectly. no gap and it looks a million times better than it used to.
Old Aug 1, 2009 | 10:47 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
good work.
glad you made it look original.
ZZ3Astro
Aug 13, 2019 12:57 AM
Elephantismo
Feb 13, 2019 12:51 AM
David Frans
Oct 31, 2015 08:12 PM
NZKnight
Oct 15, 2015 02:47 PM
z28joe2
Sep 28, 2015 05:54 PM
