What is the process for doing a firewall replacement?
Old Aug 11, 2009 | 12:48 AM
steve's Z28's Avatar
Hi, I have a 91 Camaro Z28 with heavy rust problems on the passenger side firewall where the water drains at the inner fender. It corroded so bad it created a hole in the firewall. I am planning on taking everything out of the car to make sure everything is accessible like the and wiring harnes. What steps are involved in replacing an entire firewall?
Attached Thumbnails What is the process for doing a firewall replacement?-picture-012.jpg   What is the process for doing a firewall replacement?-picture-016.jpg
Old Aug 11, 2009 | 10:30 AM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Re: What is the process for doing a firewall replacement?
I am not an expert but I believe part of the subframe is there. My suggestion is not to replace the whole thing but to cut out what is bad and weld in a patch panel. You will have to fabricate the panel but it shouldnt be that hard. The key is getting all of the rust and then sealing it with por 15 to keep it from rusting again. You just need a good mig welder.
Frozer!!!
Jan 19, 2024 04:55 PM
Cameeeero
Sep 18, 2015 04:00 PM
TheExaminer
Aug 26, 2015 04:59 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Leggman1
Aug 6, 2015 04:15 AM
