t-top interchange?
Old Aug 20, 2009 | 06:43 PM
redblazerx's Avatar
t-top interchange?
I found some t-tops out of an 87 for $50 locally. He said they were the pin style tops and so is my 92. Is there anything different that wouldnt make them fit my 92?
Old Aug 20, 2009 | 09:01 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
Re: t-top interchange?
Should fit just fine.
Old Aug 21, 2009 | 12:06 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The older tops will have smaller pins than your 1992 tops - the 1992 tops have same size pin, but they are covered in plastic as I remember, making the ending result a larger pin - the older tops have just the metal pin, thus smaller. All that's required is to get the pin holes from the donor car if possible and swap them out - they simply bolt on. Or get them off any older car with the smaller pins (or ebay, thirdgenranch, hawks, etc).
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
sbrandon
Sep 9, 2015 07:31 AM
