91-92 NON-AC cars have vacuum controlled ducts?
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Looking to swap a non-AC dash control box into my 91 Original AC car. By 91 were both AC and non-AC cars all vacuum controlled ducts?
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Re: 91-92 NON-AC cars have vacuum controlled ducts?
Bump because I was just searching this topic again and found my own unanswered post that i don't remember making!
Car: 91 Z28
Axle/Gears: Moser 9" 3.70 35 spline wavetrack
There are not very many non ac cars in those years. I also have not seen to many complete ac delete covnvertions. I haven't researched it but, most of what I have seen is just the box under the hood swapped out for a cleaner look. Everything behind the dash is different. I am running the complete setup but it is the older version. There are fresh air vents with controls under the steering wheel. I believe that those are vacuum activated on the newer versions 90 - 92 or 91 & 92 whatever it is. The older version has less ducting and holes were not cut into the dash for the ducts. The newer version has the holes and ducting so I suspect it has a totally revised system. Good luck finding one too, I wouldn't mind finding that setup as well. Older versions are hard to come by and I have only seen a few newer versions and those were in mint condition vehicles. This is probably why finding info is tough.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Yup,.... 82-89 is cable controlled and 90-92 is vacuum controlled.
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Does that mean I can buy a 90-92 non-AC interior control box and swap it right in place of my AC control box without having to make any ducting/dash changes?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
1992rs/ss
Jan 31, 2025 05:10 PM
