Is there a place to buy paint online?
Re: Is there a place to buy paint online?
http://www.paintforcars.com/
They sell paint. I don't know if you'll get an exact match to your color though. I have used them to paint a few off-road rigs. Did the job just fine.
Car: 88 GTA
Axle/Gears: 3.27 9bolt
wow that's really cheap!
witch would you think would be closer to flame red?
Burgundy Metallic Urethane
Or
Candy Apple Red Metallic ??
I also like black but im no professional.
Or
If you read the testimonials, about 3/4 the way down there is a Corvette painted with the Candy Apple Red. Guy said it came out more as a Torch Red. Just bellow that one is a Jaguar painted with the Burgandy Metallic...much darker.
Car: '00 Regal GS/'87 T.A WS-6
Engine: stock 3800 series II/stock 5L TPI
Transmission: fwd auto/stock 700r4
Axle/Gears: wrong wheel drive/3.23:1 Posi
Napa sells pints and rattle cans of your colorchoice, mixed to order. UYour local NAPA might not have the facilities to do it, but theres a Napa paint store in the area. The cheaper Finish-1 brand (used to be crossfire) is usually close...but the more expensive tec-base brand is spot on...depending on how faded your red is. If youre doing an all over paint job; Id reccomend the Tecbase since it mixes 1:1 you need half the paint...and RED paint if its cheap, takes a LOT of coats to cover well anyway.
Oh, if you do go to Napa, use the 15420 clearcoat...its awesome and 90 bucks a gallon
Car: 1992 Camaro RS
Engine: 305 TBI
http://www.paintwithpearl.com/ Lots of different varieties here.
If you need an exact match...go to NAPA, PPG or Dupont with a piece of trim from your car. Have them use a color deck or a spectrum gun...to analyze and match your paint. Every color has 3 or 4 variations...due to humidity, colorfade etc etc...just because its mixed by weight as firemist orange...and your car is firemist orange...doesnt mean its going to be an exact match. Also; dont expect the cheap stuff to have good batch control, especially with a RED and a METALLIC. buy the more expensive stuff AND youre going to need to shoot a test panel...to make sure you can get the metallic to lay down like the rest of your finish....yeah its a bit of a pain...but you want it done right
Street Lethal
Apr 30, 2019 12:14 PM
