Found some rust, need some info on these panels
Old Aug 31, 2009 | 02:53 PM
96LT4c4's Avatar
Car: 99 HOSS 6 Speed
I just bought this car and pulled it apart. I found some rust. i was wondering if anyone has some info on fixing these areas. I have looked around to see if anyone makes a replacement part but haven't found anything. I could just make some pieces and patch it up. The floor pans look pretty good so far. I haven't pulled the insulation out from under the dash yet.
This is the area behind the fender where it bolts to the body
Old Aug 31, 2009 | 03:13 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Re: Found some rust, need some info on these panels
Just take some sheet metal and make a few patches. Make sure you clean everything up real good. Paint it with por 15 or rust bullet to make sure nothing comes back
Good Luck
Alex
Old Aug 31, 2009 | 11:23 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
patch panels & por-15/rust bullet.
Then carefully inspect the rest of the vehicle,
cause rust like that usually has other company.
Old Sep 1, 2009 | 12:09 PM
From what I can see of your floor they don't look too bad. But make sure you check thoroughly, remove any rust. No matter how innocent it may look. Rust spreads as fast as rabbits breed.
Old Sep 1, 2009 | 02:36 PM
96LT4c4's Avatar
The floors look good, just some surface rust under the car. Might need a small patch around the areas you see here. I am going to put it on a rotiserie so nothing will get by me.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
neekolzun
Aug 24, 2015 04:59 PM
bjpotter
Aug 12, 2015 06:06 PM
Exxon Limited
Aug 9, 2015 08:13 PM
antares57
Aug 6, 2015 07:47 AM
