92 z28 antenna
Old Sep 2, 2009 | 09:53 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
92 z28 antenna
I am missing the antenna on my 92 z28. The base is on the fender, but the mast of the antenna is missing. I got another mast to put on, but I have noticed that the base is fairly loose on the fender. There appears to be some sort of spanner wrench needed to tighten it. I am also wondering if there is a nut on the inside of the fender that will need to be tightened?? If so, can you get to it through the wheel well by removing the wheel liner? Where can you get the proper spanner?
Old Sep 3, 2009 | 10:17 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 92 z28 antenna
Not the best procedure, but I always just got a screwdriver, stuck it sideways in the slot, and tapped it around in a circle LIGHTLY to tighten/loosen them up. There's nothing inside the fender to tighten.
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
starliner
Feb 9, 2016 08:18 PM
blackz281le
Jan 11, 2016 07:51 AM
scottmoyer
Sep 7, 2015 07:06 PM
