89 CAMARO.
Old Sep 12, 2009 | 09:38 AM
mmficeman's Avatar
89 CAMARO.
my girlfriend was closing my hatch, and didn't know how to. she dropped it about two inches above where it should be laid. now the power hatch won't work. it seems like its not aligned or something. it'll go down, and when it gets to the point where its closed, the motor will sit there and buzz. help?
Old Sep 12, 2009 | 10:14 AM
DJ Delsym's Avatar
Car: 86 Iroc
Engine: Soon to be LS 6.0
Transmission: Soon to be mn12
Axle/Gears: Strange 9in 4.10
Re: 89 CAMARO.
Not sure if I'm getting it but if your hatch motor is just on the down position poke the lever closest to the license plate with a screw driver. It will trick it into thinking the hat is closed and will pop back up so you can shut it properly.
Old Sep 12, 2009 | 11:29 AM
mmficeman's Avatar
Re: 89 CAMARO.
right, it comes up. if i set it down, the hatch will grab it and pull it down. it will get to the closed position, but when it gets there it sits there and buzzes.
Old Sep 13, 2009 | 01:20 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: 89 CAMARO.
Follow the tech article I wrote that is on thiirdgen.org on repairing the 86-87 & 88-91 hatch pull-down units. Most likely you broke either the hatch housing or the gear nut. The tech article gives the part numbers and sources for each item and instructions how to disassemble and repair it.
Lon
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
ndndndnd
Sep 28, 2015 08:00 AM
ZMWojnar
Sep 24, 2015 08:34 PM
