How to Fix Existing Hood Inserts
Old Sep 29, 2009 | 12:15 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Here is how I fixed my hood inserts, so they don't flop around or fly off in the wind. Before you read what I did, you can see a few pics of my little project. I got everything at Autozone, for less than 15 bucks.
1. I bought two of those license plate bolt kits at Autozone that have the plastic bolts and nuts in them. There are 8 bolts and 8 nuts in each kit...perfect. Four bolts are black, and four are white. The black bolts require a bit more grinding (see 3 below) down than the white ones because their heads are shaped differently, for some reason.
2. I bought some "plastic weld" epoxy.
3. I carefully broke off the broken/shortened/worthless nipples off my inserts with pliers, and this left nearly perfect depth holes to install the plastic bolts from the license plate fastener kits. I had to grind down some material off the heads of the plastic bolts, with my dremel tool, so as to make them more flat and make them seat nicely down into the holes on the inserts.
NOTE: You may also want to do a little grinding with a dremel, to clean up some of the plastic that's left in the holes on the inserts, after breaking off the useless, broken old nipples.
4. I applied the epoxy to the holes of the inserts, one at a time, and stuck the plastic bolts into the holes, making sure they were straight, like the factory nipples were. The epoxy cured quite fast and was strong.
NOTE: Don't goop a bunch of epoxy all around the holes/heads of the bolts, as this can prevent the inserts from lying flush against the metal of your hood. The small amount of epoxy I used just to stick the bolts into the holes held them in very strong.
5. I let the inserts set for 10 minutes, and they were strong enough to bolt back onto the hood of my car. Worked like a charm.
6. I recommend sanding and cleaning the inserts and spraying them with flat black Duplicolor, unless you like gloss black. They look as good as new, once this is done. New inserts cost around $150 or more.
Old Sep 29, 2009 | 12:18 AM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Re: How to Fix Existing Hood Inserts
im deffinently interested to see some pics Ive been trying to figure out a way to fix mine for awhile.....I would just buy new ones but at $135 bucks a piece last time I checked I would much rather fix mine
Old Sep 29, 2009 | 04:24 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
It took half an hour to do one insert. I've done it before, though, on my other Camaro, so it was easy for me. The first time I did it took about an hour. The engine got hot today while driving, and the bolts are still in the inserts perfectly and strongly.
Old Oct 5, 2009 | 12:48 PM
z28 TPI's Avatar
Car: '85 Camaro Z28, '90 300zx
Engine: 350 4 bolt main TPI
Transmission: 700 r4 automatic
Axle/Gears: ? not there yet, i know its stock
I believe I found another project thanks man.
Old Oct 5, 2009 | 11:44 PM
sweet thanks for all the pics, and instructions I know what im doing this weekend
Old Oct 6, 2009 | 06:38 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Cool. Yeah, the inserts are still holding strong. Good luck, and let me know how it goes.
TheTraut88
Sep 11, 2015 05:16 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
Wife'sCar
Aug 22, 2015 01:46 PM
