How to take off side effects?
Old Oct 25, 2009 | 04:36 PM
enforcer505's Avatar
Sorry if its a stupid question, but how do you take the side effects (rocker panel cover with "camaro" on it) off an 88 camaro? its been driving me nuts. i think i see 2 screws on the inside of it and no way to unscrew it. how do you even get to them? from the fender and the quarter? i just dont want to damage them and have to get other ones.
thanks for the help!
Old Oct 25, 2009 | 04:49 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Re: How to take off side effects?
The ground effects that are on the fender you mean? Or what is on the body section? Either way, there are screws along the top of the door sill area, inside the fender well along the lip, under the car, and behind the effects on the inside of the door, fender, etc. for all depending on which piece you are trying to take off. Some of them can be pretty tricky, but yes, it should just be those little body nuts behind the effects and or body screws for the rest. Just be careful and take your time. You may benefit from either a swivel socket/extension or ratchet wrench depending on location and how tight a fit it is in some of these areas.
Old Oct 25, 2009 | 07:04 PM
Iroc-Z28Man's Avatar
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
I've talked people through this before. here the link.
https://www.thirdgen.org/forums/bo...fx-anyone.html (pulling ground FX....anyone done it recently?)
Old Oct 25, 2009 | 07:06 PM
thanks for all the help. i manged to get it off and thankfully not broken! thanks for all your help!
New2Chevy
Sep 28, 2015 12:35 AM
billybob6110
Sep 23, 2015 01:30 PM
mikey8494
Aug 22, 2015 07:57 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
92firebirdchris
Aug 14, 2015 11:56 AM
