1983 Trans Am Cowl Opening
Old Oct 29, 2009 | 06:59 PM
lbarile1991's Avatar
I have a 1983 trans am. The car has the off set cowl on it. I have taken the motor off and tested it and it works. But for some reason the previousowner had shut it. How can I check to see if this opening is actually opening when I high rpm. I am not sure if it is getting the right trigger. If i am right that switch to turn it on is vacuumed. Any help would be nice.
Old Oct 30, 2009 | 10:23 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
Re: 1983 Trans Am Cowl Opening
is the car crossfire injection or carbed? If it's CFI then the hood flap is opened and controlled by the ECM from the TPS sensor.
Old Oct 31, 2009 | 10:32 PM
The car is Cross Fire. How can I locate this sensor and find out if it is working and if it is sending a signal to the cowl?
1992 Trans Am
May 10, 2023 07:19 PM
Street Lethal
Apr 30, 2019 12:14 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
eddie jr
Aug 25, 2015 06:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
