Fog lights...
Old Nov 25, 2009 | 08:33 PM
oscarsrs's Avatar
Car: 91 RS/ QX56/Altima 3.5 SE
Transmission: AUTO
Axle/Gears: ?
Fog lights...
ok i was thinking about retrofitting aftermarket foglights into the turn/parking light housing (ebay pair) and then to keep use of the turn signal and keep it legal to use a led strip around the housing.
now the reason for this is i have an RS and i like my grill, i know the Z28 looks better and has fogs but to keep some what of the stock clean look, i think this would be a cool mod.
what do you guys think ? let me hear your input thanks
Old Nov 25, 2009 | 11:11 PM
TXBowTie40's Avatar
Re: Fog lights...
#1, I think you posted this in the wrong forum!!
Old Nov 26, 2009 | 09:40 PM
oscarsrs's Avatar
Transmission: AUTO
Axle/Gears: ?
Re: Fog lights...
oook, so if this is the wrong forum can a moderator please move it to the correct one please, thank you
Old Nov 27, 2009 | 08:55 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Fog lights...
What about mounting the fog lights in the stock location behind the RS grille? Then you get to keep the grill, and have the lights. They will mount behind, and shine out through the slots.
Old Nov 27, 2009 | 11:22 AM
oscarsrs's Avatar
Transmission: AUTO
Axle/Gears: ?
Re: Fog lights...
Yeah I thought about that but I think the mod would give it a more modern look with the leds and all and at night it will look more aggressive in my opinion
Old Nov 27, 2009 | 11:23 AM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
Re: Fog lights...
I myself an also thinking of adding some fog light behind the RS grill i thinking by the end of this week having them install
Old Nov 28, 2009 | 03:59 PM
oscarsrs's Avatar
Transmission: AUTO
Axle/Gears: ?
Re: Fog lights...
cool, if you can when done upload some night shots to see how it looks, i really dont think the light would shine thru good enough cause the bars on the grill are tilted towards the bottom so yeah you will see light coming out but thats about it . i could be wrong please let me know how it works out for you.
thanks
Old Nov 30, 2009 | 10:04 AM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
Re: Fog lights...
I will do. I am sorry I didn't had a chance to do it Sunday I had some things to do put today I should have a picture
Old Nov 30, 2009 | 10:20 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Fog lights...
You would need a high intensity LED, nothing cheap because when the fogs are on, you will not see them. The LED's will almost need to be blinding to over power the fog's output to be seen safely. Also remember, if your not wiring it yourself, you will need a second strip for parking lights, that aren't as bright. They don't need to be blinding as the turn signals will have to be, because if the fog light is on, then your seen. If the fog light is burned out, they will see the parking light LED strip. Basically you will be battling the brightness of the fog light to make a safe turn signal. That's why in most cases, the fog light isn't as close. Only a few i've seen together like the pontiac grand prix as of late and a few others. All in all, i've thought about something very similar, but decided to go z28 grill and z28 fogs.
1992Z28!
Nov 19, 2015 07:33 AM
Eric-86sc
Exterior Parts for Sale
Nov 16, 2015 10:20 AM
sbrandon
Sep 9, 2015 07:31 AM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
