why does my speedo bounce
Old Dec 3, 2009 | 05:48 PM
rad russ's Avatar
Car: 1987 IROC Z
Engine: 5.7
The needle on my speedo bounces when I start off drivin up till like 25 mph?
Old Dec 3, 2009 | 06:01 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
Re: why does my speedo bounce
you need a new cable....
Old Dec 3, 2009 | 06:25 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
More than likely, you need to clean the cable and housing:
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
Old Dec 3, 2009 | 06:36 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
It bounces because it wants to go club hopping.
JK... I have the same issue with mine. After I hit about 30mph I have no idea what my speed is. One time I got going ~90mph down the highway and the thing just kept swaying between ~75-110mph.
Old Dec 3, 2009 | 06:56 PM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
yeah a new cable would help but it wont help if the cable connectors are dirty. take the cable off your tranny and clean the hell out of it. take the cable out of your speedo and clean it to. check your cable, if its not a straight rectangular bar than you need a new cable.
Old Dec 3, 2009 | 08:56 PM
JamesC's Avatar
Cleaning and lubing instructions are provided in the link I provide above.
JamesC
Old Dec 3, 2009 | 09:11 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
I have the same problem when I reach like 80 it starts floating, but then when i hit like 95 it goes back to normal it always does it exactly the same too. I'll have to try giving it a nice cleaning, and lube thanks james c for the great write up
Old Dec 4, 2009 | 06:55 AM
JamesC's Avatar
92RS, 82-89 cars have mechanical speedos, 90+ have electronic speedos (There's no cable to clean/lube).
JamesC
Old Dec 4, 2009 | 07:16 AM
GICATA's Avatar
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
Mine bounces a little too...I'm pretty sure it's been pegged out to hard, too many times!
Old Dec 4, 2009 | 07:24 AM
JamesC's Avatar
More than likely the cable is OE, meaning that it's trying to function on 25+ year old lube, which has turned to worthless gunk.
JamesC
Old Dec 4, 2009 | 07:27 AM
Twin_Turbo's Avatar
Clean the cable and lightly spray the steel drive cable with some moly spray. Do not use grease as the way the carble turns the grease is forced up into the speedo and this will deteriorate the speedo head plastic over time. A very common problem on older cars w/ cable driven speedos. The plastics don't go well with the grease.
Old Dec 4, 2009 | 09:06 PM
JamesC
mine is an 89 I sold my 92 years ago
Old Dec 4, 2009 | 10:10 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
I believe it could also be the speedo drive in the tranny, my was cable drive and did this, I changed to a Covan dash which came with a Autometer electric speedo and it still does it and it now does not have a manual cable
Old Dec 7, 2009 | 09:01 AM
1Aauto's Avatar
Former Sponsor
It's more than likely the speedo cable. Had the same thing happen in my car after to many passes down the 1320
Old Jun 9, 2025 | 06:14 AM
89RedFormula's Avatar
Car: 1989 Pontiac Firebird Formula
Engine: 305 TBI (stock)
Transmission: T5 (Converted May 2025)
Axle/Gears: 2.73, non-posi drum
My 89 Firebird with a T5 has a gear-driven VSS:
T5 Camaro Firebird Large Can Speedometer Sensor 10456087 USED T-5 Speedo - Picture 1 of 8
T5 Camaro Firebird Large Can Speedometer Sensor 10456087 USED T-5 Speedo - Picture 3 of 8
The VSS unit I bought during my 5-speed swap came equipped with a 22-tooth gear, but after the swap my speedo was reading 10% low, so I was able to source a 19-tooth gear to account for some speedo inaccuracy (although now it reads 5% fast)
Now I get some minor speedo wiggle above 50 mph - think: +/- 1 or 2 mph, with more variation the faster I go.
I know the drive gear on the output shaft is a red 7-tooth and that the 7-tooth drive / 19-tooth driven gear combo is one that is commercially available for cable-driven speedo setups. Any ideas on cause?
rs_z28_vert
Sep 30, 2015 09:47 PM
IROCtometal
Sep 20, 2015 11:08 PM
TrevinE
Sep 14, 2015 03:20 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
