Windshield washer help
Old Dec 6, 2009 | 01:41 AM
basiccamaro's Avatar
Don't know if this is the best section for this question or not, but here goes-
I've got a 1983 Berlinetta and I can't get the windshield washers to work. This has the small square at the top of the wiper motor housing on the firewall, with three lines coming out of the cover pointing at an angle up and off to the right side of the car.
Today I took all of the lines off, cut the ends back a short way to fresh hose, made sure the end sprays were open, made sure the left and right lines were open, made sure the line from the washer fluid tank to the pump (the square top plate with the three lines coming out of it) was open and clear, and blew out and cleaned the pickup screen in the fluid tank. But it did'nt help any at all. When I run the wipers and rotate the thumb lever for the washers, I hear clicking noises. I've tried it both with and without the wipers running.
Is there anything I'm missing? Should I check for voltage going into the wiper motor housing? Does the washer work on vaccuum off the wiper movement?
I'm about ready to just go get a generic pump from NAPA and bypass the the stock pump altogether. Is there a good 12 Volt hot- with- ignition- on wire close by on the firewall to tap into for an add- on aftermarket pump?
Does anybody know which wire is run by the washer thumb switch on the turn signal lever stalk on the steering column?
Old Sep 12, 2013 | 05:07 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: Windshield washer help
Any updates?
Old Sep 12, 2013 | 08:42 AM
Lakerman62's Avatar
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
Sounds like u may need a new motor if everything else checks out/is connected. They are cheap @ NAPA.good luck.
Bohemian
Aug 15, 2017 05:11 PM
Fireslash
Apr 11, 2016 06:43 PM
m00n420
Sep 11, 2015 02:39 PM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
