500hp and t-tops?
Old Dec 7, 2009 | 04:51 PM
Eivind's Avatar
500hp and t-tops?
Hi
I have a 350 gta with t-tops, and are aiming for 500hp.
Will the body handle all that power or do i have to reinforce it? :P
Old Dec 7, 2009 | 05:00 PM
toomany's Avatar
Re: 500hp and t-tops?
Even a hard top would need help with 500hp. These cars are far from the stiffest in factory trim. SFC's are a big help even on a six cylinder. I'd start with weld in SFC's and if you feel that isn't enough, build a cage to help tie everything together.
Old Dec 8, 2009 | 12:08 AM
Black_Knight's Avatar
Car: 1985 Pontiac Trans Am
Engine: 305TPI
You will need sub-frame connectors at a bare minimum. If you plan to push it at the track, then a partial cage is highly recommended. A full cage is of course better, but not everyone wants to deal with that.
I'm in the same type of position myself and this is the conclusion I've reached.
Old Dec 8, 2009 | 02:21 AM
Motopsyco's Avatar
Car: 89 firebird, 03 Avalanche z71
Engine: 5.0 stock (for now)
Transmission: 700R4 auto
Axle/Gears: stock 2.73 for now
yea like they said, in a t-top or even a hard top, youll need sub fram connectors at the very least and a roll cage at least a partial to connect the rear frame and front unibody section together to at least help with the frame twist youll get with 500 hp.
Old Dec 9, 2009 | 05:44 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
i got 500 with ttops, but have nasty subframes, no cage...did fine at the track, its all how you launch the car, if you spin, you be fine, if you hook, thats where the trouble starts
Old Dec 9, 2009 | 05:47 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
I have 600hp with t-tops but i have an 8 pt. with frame connecters.
Old Dec 10, 2009 | 10:18 AM
1Aauto's Avatar
Former Sponsor
With that HP, I'd do subs at a minimum.A cage would be a good idea though.
Old Dec 10, 2009 | 10:19 AM
Engine: 305TPI
Which sub-frame connectors did you go with?
Old Dec 10, 2009 | 10:31 AM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
I have somewhere around 450 in my Z28 and it bent the frame bad enough that the driver door doesn't close right. Go with sub frame connectors just to be safe
Old Dec 10, 2009 | 11:08 AM
Engine: 305TPI
I would never fire up a 3rd gen with that much power if it didn't have sub-frame connectors fearing that very problem.
Old Dec 10, 2009 | 11:11 AM
theNMBR27's Avatar
I kinda wish I hadn't, but it freaks my friends out that don't like third gens
Old Dec 10, 2009 | 11:12 AM
Engine: 305TPI
What freaks them out? The fact that the car has that much power?
Old Dec 10, 2009 | 11:22 AM
theNMBR27's Avatar
yea, they still like those low displacement factory turbo cars.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
