Door Lock button works but Unlock doesnt
Old Dec 10, 2009 | 06:46 PM
WolfsCam19's Avatar
Car: '92 Camaro RS | '11 E92 335i
Engine: 305 TBI V8
Axle/Gears: Stock
WHY! please someone help me out, actuator works up but not down... could it be a false ground? cleaned and lubed the rods which helped it lock smoother but still NO unlock. could it be a bad actuator??
any input would be appreciated, thanks!
Old Dec 10, 2009 | 07:21 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Re: Door Lock button works but Unlock doesnt
if the other door buttons work try swapping just to rule out that its the button.
if you dont even hear a clicking sound when pushing unlock its most likely the button.
if you hear anykind of noise when pushing it but the door still doesnt unlock or fully unlock.
take off the door panel and lubricate the actuator and metal sticks that make up the door locking/unlocking setup. might just be too much friction to overcome to open the lock.
most likely bad button or stuff needs lubrication.
Old Dec 11, 2009 | 06:41 AM
WolfsCam19's Avatar
Engine: 305 TBI V8
Axle/Gears: Stock
yea I havent tried taking off the door panel yet so I guess thats the next step but its so *** cold out ha. The weird thing about it is that both door lock buttons work fine but both unlock buttons dont. You can hear and feel both sides of each button click too but the unlock just seems to disagree with me. I also dont know if the car previously had a car alarm or keyless entry system installed which might effect it but I'm just not sure at this point. Hopefully the panel works otherwise I'll be back for more. Thanks for the post!
Old Dec 11, 2009 | 06:10 PM
Bobby_80s's Avatar
Axle/Gears: no idea
if both unlock dont work, might wana try looking under the driverside kick panel. there are relays for the locks drill a new hole to make sure there is a good ground and check the wiring.
just another thing to rule out
Old Dec 13, 2009 | 12:27 AM
WolfsCam19's Avatar
Engine: 305 TBI V8
Axle/Gears: Stock
if it was a bad ground wouldn't the lock button not work at all as well then?? Can the relays go bad too and that be the reason why unlock doesn't work?? Also saw today that the unlock and lock wires were tapped into due to aftermarket keyless entry or alarm??
Old Dec 13, 2009 | 02:15 AM
Bobby_80s's Avatar
Axle/Gears: no idea
not saying ground is the problem just saying its another problem with our cars that eventually need to get fixed.
and maybe the previous owner bypassed the stock relay and the keyless entry went bad.
not sure. i would try to undo the keyless wiring and see what happens but at least check the wiring to the relays which is behind the driver kick panel
Old Dec 13, 2009 | 10:00 PM
87whiteiroc's Avatar
Car: 87 Camaro
Engine: 5.7 350 TPI
had the same problem with it not unlocking. like mentioned before just take the door panel off and lubricate.
Old Dec 14, 2009 | 09:25 PM
WolfsCam19's Avatar
Engine: 305 TBI V8
Axle/Gears: Stock
can one of you upload a photo of the ground because I dont see any wires grounded anywhere. I see a ground screw but no wire so I'm wondering how messed up my whole relay wiring system is. I also terminated all possible keyless entry or alarm wires and still no unlock.
Old Dec 14, 2009 | 09:30 PM
Bobby_80s's Avatar
Axle/Gears: no idea
the relay housing and screw is the ground. thats normal. im sayin that over time that ground hole gets alittle worn/rusted and doesnt make a good ground anymore. drill a fresh hole right above or below and might find to have a stronger open and unlock function
Old Dec 15, 2009 | 08:43 AM
WolfsCam19's Avatar
Engine: 305 TBI V8
Axle/Gears: Stock
my relay is just kinda hanging there though right next to my fuse box. It isn't screwed into anything. I'm starting to wonder if its just the unlock wires that run from the relay to the motor.
Old Dec 18, 2009 | 09:45 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
You're probably talking about the starter enable relay... The thing you're looking for is down under the panel where the hood release is. It's gold in color, and has 2 relays in a "compact" single housing. I'm willing to bet that the unlock relay has crapped out, since the other works. In my experience, if that ground is bad, neither lock or unlock will work, but the relays will click.
Old May 13, 2015 | 02:32 PM
rdhanded2's Avatar
Top Answer: 1
Car: 91 TA / 91 Formula
I am having similar issues on my Firebird and I just wanted to ask and make sure before I go messing with anything. Hitting lock works fine from both the driver side and passenger side doors. If you hit unlock it does not move at all and I can hear a click at the dash. Everything is lubed up and moving freely otherwise, definitely not a lubrication issue, and as I said, I can hear a click at the dash when I hit unlock.
Old May 15, 2015 | 06:40 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
I have the same issue on the drivers side.
It will unlock fine but you will have to hit the lock button multiple times for it to lock on the drivers side. The passenger side power door locks work flawlessly.
Old May 15, 2015 | 07:12 AM
rdhanded2's Avatar
Top Answer: 1
That's not the issue I am having. Mine will not move at all no matter how many times you hit the button, it just clicks, Your just needs greased and it should work great. Spray the rod in the door with lithium grease and work it back and forth a few times and spray again.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
