T-top rail?
Old Dec 12, 2009 | 12:57 AM
Jazz T/A's Avatar
Car: 82 Trans Am, 68 El Co, 84 K5
Engine: Carb 350, Carb 327, 6.2 Diesel
Transmission: Borg-Warner T10, TH-350, 700R4
Axle/Gears: 3.23, stock 10 bolt, 3.73
T-top rail?
i have a 82 t-top trans am and my center t-top rail is rusted and i want to replace it.
i found 1 at hawks third gen but its listed as a 85-92. will it still fit? or are the t-tops shaped differently?
ant this is what i need to replace.
thanks.
Old Dec 12, 2009 | 01:57 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: T-top rail?
I'm not sure if they changed from '82 on up but I have some pictures for one I posted for sale (here) if that helps. I have heard of people swapping the latches from the hooks to the pin types so I imagine the middle bar would be the same.
Old Dec 12, 2009 | 10:27 AM
Jazz T/A's Avatar
Re: T-top rail?
well they look the same.
What year is that from?
and could i use the part from a camaro?
Old Dec 12, 2009 | 11:27 AM
Scorpner's Avatar
Engine: V6, V8
Re: T-top rail?
It's from an '86 Firebird. On this particular part I don't think it would matter between a Firebird and Camaro. I bought it for my Camaro in case I need it if/when I ever get around to repainting it. I guess if you found someone locally with an '86 and tried one of your T-Tops on it you would know for sure about the T-Top bar. The hooks obviously won't work, but it should set in place regardless.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
gixxer92
May 18, 2017 11:20 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
bplessy
Sep 30, 2015 12:14 PM
