rear spoiler swap
Old Dec 17, 2009 | 12:52 PM
Zeromitch87's Avatar
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
rear spoiler swap
I'm going to swap out my rs spoiler for the high rise. will there be any holes after i install the new spoiler and if so whats the best way to cover them?
Old Dec 17, 2009 | 01:02 PM
Stephen's Avatar
Car: 87 GTA
Re: rear spoiler swap
Yep. EVERY hole between the RS & 91-92 Z28/high rise are different. Weld shut & repaint is the only real way to get rid of them.
Old Dec 17, 2009 | 01:10 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
bondo the holes maybe? if u dont have a welder...just my 2cents
Old Dec 18, 2009 | 07:58 AM
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
Won't welding be to much for the thin metal. im kinda stuck on this i want to do it right and not have it crack up my new paint job when i get it painted. will just bondo alone do the job?
Old Dec 18, 2009 | 08:10 AM
Stephen's Avatar
Car: 87 GTA
Welding won't hurt it, if done right. MIG or TIG only. Arc welding will blow right through the thin metal.
Bondo COULD be used, but there wouold HAVE to be a backing plate, nut just bondo plugging the hole. Without a backing plate, it is much more likely to crack in the future, pop out (bondo "grows" when it cracks) & require repainting afterwards.
Old Dec 18, 2009 | 08:25 AM
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
I thought so, but my dad just got done telling me the metal was to thin. he knows ALOT more about cars than i do so i wasn't sure. i'm gonna have my friend mig weld it i hope it doesn't burn right through it V_V or should i bondo plug the hole? thx (won't i use bondo anyways after welding and grinding it down?)
Old Dec 18, 2009 | 08:37 AM
Stephen's Avatar
Car: 87 GTA
Like I just said.....
MIG or TIG. How do you think Body shops do metal work?
When my GTA wing was swapped out for a 4th gen wing, we had to weld up 4 holes. My 110 MIG was used & did just fine. If your friend knows how to MIG good, just turn the heat on low & go.
Old Dec 18, 2009 | 08:40 AM
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
Thank you. If all goes well, i'll post up a pic later this week
Old Dec 18, 2009 | 01:51 PM
88camaroluvr's Avatar
You could also just get the rear decklid cover that came with a car with the high rise. simply unbolt it from the old car with the spoiler, paint it, then bolt it onto yours.
Old Dec 18, 2009 | 02:30 PM
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
i have thought of that, but that's more money than filling the holes. plus that only fixes half the problem, the spoiler has 3 pieces, decklid and 2 sides. i think those holes would still be there on the sides
Old Dec 18, 2009 | 02:38 PM
Stephen's Avatar
Car: 87 GTA
Yep. You'd still hafta close 3 holes (per side) & paint.
LilHot
South Central
Apr 13, 2026 11:46 PM
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
