so no cheap/real projector headlight for 91-92?
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
so what ive read in previous posts.... correct me if im wrong or things have changed.
ebay projector headlights are fake for the part.
and real projector headlights either cost a fortune or you gota fabricate to work for your car?
im trying to see if i can get a pair for my 91-92 style trans am headlights.
and what happens for high beam? does it have it? dumb question maybe but i dunno anything about these headlights. just like the look of it
so if anyone has any links to real projector headlights for 91-92 trans ams or any info let me know.
thanks
thanks
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: so no cheap/real projector headlight for 91-92?
thanks
thanks
half the cost, fabricate ones yourself. 400-500
high beams:
2 headlamp system (f-birds): use bixenon projectors, a soleniod flips the cutoff shield inside the projector allowign more light to shoot up and down the road, almost like the equivalent of a dual filament headlight bulb on a 2 headlamp system
4 headlamp system (maro's) can use bixenon's since the lows are dual filament but easier to just do regualr low beam projector and keep the 2 middle lights as highs.
i'll edit with pics
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
wrong-o-mundo. do those if you want but...
high beams:
i'll edit with pics
high beams:
i'll edit with pics
As stated above:
In a bi-xenon projector(2 projectors,meaning both hi/lo are incorporated).The hi-beam is handled by a solenoid in the projector that flips down.Thereby unblocking the HID lamps & allowing all the light out.
There is no 2nd HID lamp for the hi beam.The hi-beam circuit(wires) is connected to the solenoid.So when you switch on the hi-beams, the circuit powers the solenoid, NOT another HID lamp.
For vehicles with seperate hi beams(4 headlamps).Even when the lo-beam is a projector(single xenon).The hi-beam is not HID & seldom a projector.This is because you loose the "flash" function with HIDs.So the hi beam is left as an incandescent system.Its also cheaper to manufacture this way.
You can do it for less than $1000.
Axle/Gears: no idea
too rich for my blood. i just like the look. and trying to be unique. and i dont like the blue light looking headlights a nice white is better than yellowish. but teh proejctor lights just look badass.
o well
o well
Axle/Gears: no idea
one question guys.
if i found a set at a junk yard cheap to fabricate. what parts do i need. just the projector module it self? any harness or connectors or whatelse?
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
If its an HID system, you'll want as much of if as possible(harness,lamps,ballast) & of course the projectors.Only the porjector itself is required, but you can also take the shroud.Though i doubt it will look right in the f-body style housings.
An HID system from a salvage yard is probably gonna cost you a pretty penny.So its still gonna be "too rich for your blood".Better off pieceing it together here & there.
Im guessing you meant cant or shouldnt, more like it.Some of you guys think you need 4 HIDs.Two for hi, two for lo.This is unneccessary.
As stated above:
As stated above:
i meant that in our cars the outside lights have both low and high beam terminals, while the inside lights only have high beam terminals
so a bixenon projector for the outside lights, with halogens in the middle would in theory be the correct conversion.
i.e. on the new (06-current) lexus IS-series with the hid option, the projectors are bixenon, with regular halogens in the middle also. the solenoid does not flip all the way, i would guesstimate about halfway
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Nope, incorrect.
You do NOT need a bi xenon projector for the camaro.A single xenon projector will do the job fine.
Whats with wanting two hi beams or two lo beams(per side).Your theory implies a system with 4 hi-beams!Whats the advantage?If your thinking more/better lighting, feel free, but the single xenon projector will output far better by itself.
If your that hard up for running a bi-xenon projector in the camaros.Then just leave the hi beam out(or remove it alltogether).The bi-xenon will do a better job.If your car already has the hi/lo in one lamp(firebirds).This is the way to go, but since the camaro has a seperate hi-beam.Its simpler to just leave that way.
I have no hi beam(bi-xenon) projector on my car & the xenarc system doesnt modify the headlight wiring.Only the lo beam is HID, the xenarcs hi beam circuit uses a H9 lamp.All i did was replace the reflector lamp with a projector, nothing else.
With the projector installed the hi beam is barley noticeable when switched on.An HID lamp inplace of the H9 would just make the light brighter & create glare, thus blinding oncoming traffic.
Its difficult enough modifying the lights as is, why complicate it more.Keep it simple!
Not all bi xenon projectors flip the cutoff shield all the way down.The E55s in my bike dont.This is due to DOT regulations, again this is to not blind oncoming traffic.Has nothing to do with whatever other lamps are on the vehicle.
Car: '91 TA vert
Engine: turboLSx
What's wrong with wanting a bixenon low/high and another high beam?
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Need and want are two different things. You didn't need LED lights and HIDs at all. But there are four housing available on the front of a Camaro, why not take advantage of them? If my bird had four housings, they'd get four bixenon projectors. Overkill? Yes! I'm not going to blind anyone with the light directed correctly and it just means my night vision is that much better.
Halogen lights in general are shitty, inefficient designs.They waste alot of energy (current)just to heat the filament.Manufactures did as much as they could with halogen technology, like difuser(fluted) lenses,dual filaments(H4) & higher wattage just to improve lighting.Silverstars are the best halogen ive ever seen though.
HIDs are so good ONE lamp(per side) can do the job of both hi/lo without the need for another HID lamp for the hi beam.No need for fluted lenses, dual "filament" or mulitple lamps either, all while operating at lower wattage than traditional halogens!That was the whole point in the first place.Simpler, better, efficient, etc.
Wanting/needing (whatever the you wanna call it) more hi-beams.Is equivalent to stacking a Rr wing on top of an existing wing or hoods with iroc louvers on top of a hood scoop.Its the more is better theory!
I think the advantage is fairly obvious. More light directed in the correct place. How does one xenon capsule/projector output better alone? Care to elaborate? Having the Bixenon also stresses the capsules less if you're a frequent "flash-to-pass" type of person because you're not flicking the capsules on and off.
One projector(per side) produces a better beam than four(2hi/2lo) halogen lamps, THATS HOW!Four HID hi beams or multiple HID lamp systems seem pointless.Ever noticed two vehicles each with HID projectors parked next to each other.How much better was the light from both vehicles combined?
I dont even know what you mean by "stressing the capsules less" or even if you know what bi-xenon means with regard to the projector & a bi-xenon HID lamp.Not the same thing exactly, nor do they go together.
The high beam is barely noticable because it's a halogen that is directed everywhere. Yes, the H9 bulb puts out a hell of a lot more light than even an upgraded H4 bulb, but it's output is being thrown everywhere, the concentration is less. If you have proper projectors then there will be no glare.
Even with an HID the difference is little to none.Maybe with a projector(w/HID only) there is some improvent, but again this means re-working not only the stock harness, but also the HID harness for the lo beams.
Nothing wrong with this at all, but with the work required Vs gain i see little reason to do this.If the OEMs though it was a worthy advantage you'ld already see systems with HID lamps on the hi beam side.
If you wanna run multiple HIDs go right ahead!Knock yourselves out.I was just posting my 2 cents worth......seacrest out.
Car: '91 TA vert
Engine: turboLSx
