T-Top Mod
Car: 1987 irocz
Engine: 305 tpi
Axle/Gears: g80 posi
Re: T-Top Mod
DAREDEVIL 1, Here is the pictures of the piece that is broken inside of my steering column.
https://www.thirdgen.org/forums/inte...ml#post4425653
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: T-Top Mod
the part you broke is directly under the lock plate correct? i just looked in my 87 shop manual and its called a cancelling cam assembly. i wish it gave me part numbers. let me know if this helps. i relize this is an older post so you may have already solved this prob.
Car: 1987 irocz
Engine: 305 tpi
Re: T-Top Mod
i had that same exact wheel on my 88. i loved it. the 87 i have now has a 3 spoke chrome one. not really a fan of it. chrome shines in your eyes sometimes..lol. dont for get to rent the lock ring puller from autozone. there is no way youd want to take out that lock plate with out it. that spring is really pushing on that plate. really you could have the wheel off and that piece changed in under 20min. good luck and let me know if you run into trouble. its still fresh for me since i just tightened my tilt column and had to tare it down more than that.
Re: T-Top Mod
Good deal bro. Ill let you know how the cam replacement goes. Good lookin on the rental tool from AZ.
Re: T-Top Mod
Will trade for right hand side.
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
Car: 1983 camaro z28, 1981 honda cb650
Engine: Lu5 305 crossfire v8
Axle/Gears: 2.93
Re: T-Top Mod
I bought a few sets recently, I think they're acutally a good deal for around fifty bucks a set. At first I thought they were a rip but they're much better quality than the originals
Thirdgen89GTA
Nov 26, 2015 11:04 PM
