steering wheel horn cylinder contact.
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Does anyone know where I can get a new little cylinder retainer that holds the spring loaded horn wire onto the contact for the horn? The cylinder that is broken is the piece where the pen is pointing, not the spring wire piece.
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: steering wheel horn cylinder contact.
That would be the turn signal cancelling cam. Tough to find in a yard unless you happen to own a steering wheel puller and a lock plate remover or the column is already in pieces. Try to find one at an auto parts store.. They may have it. While you're there, you can rent the 2 tools I listed above.
Maverick H1L, Is this the correct cancelling cam for my 86 IROC-Z? or is it a different one than the one in the picture.
http://cgi.ebay.com/ebaymotors/ws/eB...d=360056014900
No. Go to just about any autoparts store and look in the HELP! section. There are only two varieties for GM cars. A white and a green, I want to say the green is for non-tilt columns, white is for tilt columns.
https://www.dormanproducts.com/cgi-b...tegory_list=:0
Type: Turn Signal Cam
Make: GM 1995-74
OE #: 26029509, 26047013, 7812051, 7812211
Brand: Dorman - HELP! - Carded
Application Notes:
w/Tilt Wheel
Make: GM 1995-74
Application Notes:
w/Tilt Wheel
Actually, this is the part that I need. Just this piece. If you look closely, you can see the cut at the top where the black tube (my first picture) would screw into. I'm going to call GM to see what they say. Thanks guys.
Never mind. the tube is on the bottom of the cam.
Veryfied. Check it out---
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
JamesC
. Time to rent some tools from AutoZone. Thanks for the tip JamesC. Thread Starter
By the way, is my steering wheel OEM for my 86 IROC-Z?
That steering wheel is out of a Chevy truck... Early 90's S10 or Tahoe, Silverado, etc. All Z28's up to 89 came with a 3 spoke leather wheel with the Camaro emblem in the middle, including Irocs.
Damb it!!!!!!!!!! I like my steering wheel so much. CRAP!!!!!!!! I'ma have to do some fishing then. Is this the proper one?
Better yot this one right?
The first one you posted is the vinyl/plastic Berlinetta style wheel, the second one looks right. There are some minor differences along the line, but they're all basically the same.
As you might have guessed, finding a 20 year old leather steering wheel in good condition isn't easy. That's why Grant wheels, and substitutes from other cars (like the Berlinetta wheel) are so popular. It's been common to see other wheels, even 3 spoke Firebird wheels in Camaros since the early 90's.
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
I chose a Grant because of its general similarity to OE. Should you wish to compare, there's a pic in my Car Details below.
JamesC
JamesC
Grant looks very similiar. Also yup, the dash does look very nice.
Car: CAMARO,GMC SUBURBAN DUALLY,RACEBOA
Engine: 305 TBI( soon 383),350Vortec
Transmission: 700 turbo
http://www.compnine.com/index.php?na..._search=Search <<<<<<<< LOOK !!!!!
But,,,mmmmmmmhhhhh...thats the part # i gave u and u said >>thats not it !!!!!!
UUUhhhhhhh
OOOppppsssss. I stand corrected. Your right. One more time
. Go ahead DAREDEVIL 1, take a shot at me
. Member
