Hate it when you just can't think of the word to describe it??
Old Jan 26, 2010 | 02:07 AM
48jeepster's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
I'm looking to replace or remove the IROC emblems that are located on the outside of the door skins that surround the door lock cylinders. The IROC I just bought has them, and they're bubbled/yellowed/rusted, and quite unsightly.. Anyone know exactly what these are called? If I can, I'll provide a picture of exactly what I mean..
Old Jan 26, 2010 | 07:06 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: Hate it when you just can't think of the word to describe it??
No need. They are aftermarket and were a horrible idea to protect the paint around the keyhole from key scratches. The best way to remove them is to heat the area with a hair dryer to soften the adhesive. Use a piece of string to get under one corner and gently pull the corner away enough to get a grip on it. Using pliers or fingers, gently pull while applying heat until removed.
Those were usually sold in the 80's so the paint might be faded around these compared to what's under them. You may need to compound the doors blend any paint differences.
Old Jan 26, 2010 | 09:33 PM
48jeepster's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Thanks man. That's what I figured, but I was afraid that if I removed it, there would be holes or something, but now that I know it's just adhesive, I'll be removing them. Thanks again.
Old Jan 26, 2010 | 09:49 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
12 lb test fishing line works great as well!
RS Reaper
Oct 17, 2018 07:52 PM
sammy52401
Nov 11, 2015 07:20 PM
88CamZ
Oct 8, 2015 10:29 AM
Fanatic1074
Oct 2, 2015 03:47 PM
Twinn Engines
Sep 25, 2015 06:27 AM
