Fender rust rust rust?? What should i do? Cheapest way?
Old Jan 28, 2010 | 10:29 AM
augie1209's Avatar
Okay so I bought my 92 z28 in August. It needed a new fender (passenger) due to a minor wreck. When i removed that last bolt (the one closest to floor pan, which I'm not even sure if that was the floor pan or not) it was rusted to all hell and i ended up having to break it off because bolt wouldn't come out. Now with new fender i have nothing to attach that section to so its pretty loose causing alot of rubbing when you open door. I need some advice on how i should go about fixing this. Also I plan on possibly putting lambo doors on it soon (universal weld kit, don't judge just need advice please) and need to access both inner fender walls. Well on driver side, I can already tell that I'm going to have the same problem because the rust is almost completely covering the bolt. Help me out here any suggestions? Is this the floor pan or part of chassis?
Thanks for help!!
Old Jan 28, 2010 | 12:34 PM
BMR Sales's Avatar
Former Sponsor
Re: Fender rust rust rust?? What should i do? Cheapest way?
Thanks for help!!
Your going to need to ghet that bolt out. Use pb blaster or another rust penetrater and an ez out or drill the remainder of the bolt out and get it out that way.
Old Jan 28, 2010 | 12:56 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Not to add to your to do list but, be sure to take a look at the floor board area where you're having trouble. Check for rusted body and floor boards. This is a catch & collect, long term rust trouble area.
Good luck with your project
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
jovibuilt
Oct 18, 2015 08:12 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
88CamZ
Oct 8, 2015 10:29 AM
Damon
Sep 26, 2015 04:29 PM
