modern paint questions
Old Jan 24, 2010 | 04:54 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
I'm thinking ahead to repainting my camaro after I finish my 58 impala project.
I know how to get good results with lacquer, and feel it's not the worst option for a garage kept car, but I'm open to a more modern paint for a more modern car. Lacquer paint can look amazing for years if you take cae of it, but when neglected, it's terrible
Can you tell me what kind of paint you all like? Is there a single stage out there that is worth using? Or do all of them pail to the results of BC/CC?
for single stage urethane, do you sand and polish it just like lacquer? What makes it shine?
It's a little intimidating moving away from what you know into the unknown, but I can't think of a good reason to paint an 89 with lacquer other than it's easy, and that's probably not a good enough reason
Old Jan 24, 2010 | 04:57 PM
Aldakoopa's Avatar
Car: 1987 Trans Am
Engine: 305 4 bbl
Transmission: The kind that goes "kachunk" in 1st
Re: modern paint questions
Personally, I like Nason BC/CC made by Dupont, but I don't know how much longer it will be availiable.
It's cheap, easy to use, covers well, and makes a great looking job in the end, and I haven't seen any problems with it. If the car is garage kept, that will definitely help as well.
Old Jan 24, 2010 | 05:20 PM
Xx89CamaroRSxX's Avatar
i went to school for automotive collision repair and refinishing so mind me that i know what im talking about. with painting bc/cc is the top and only way to get the right paint job. now depending on your skill the steps you take and the paint you use will decide how it comes out. but bc/cc will last longer then pretty much any other kind of paint. in school fer our production work we use alot of dupont and PPG paint. both came out perfectly fine. higher end shops who do wprk with bmw and mercedes and all that use sikkens. there the high end brand of paint.
Old Jan 24, 2010 | 06:02 PM
58mark's Avatar
thanks. It's easy finding information on BC/CC, but SS urethane is a lot harder. Doing it myself, i'm not so concerned about it being the longest lasting paint job, but one that is easy to put on, and easy to touch up
Old Jan 24, 2010 | 06:33 PM
id say bc/cc isnt hard to work with, being a freshman in high school with no prior knowledge was still simple in general to spray. you just need to know the correct air pressure and all that.
Old Jan 25, 2010 | 09:51 PM
UDAMON's Avatar
Car: Mazda Protege5
ive heard SS requires the same maintenance as lacquer.
also you cant shoot lacquer over enamels so keep that in mind.
Old Jan 27, 2010 | 02:46 PM
steve87ta's Avatar
Car: 1969 firebird, 1986 Trans Am,
Engine: 461,305TB
Transmission: T-10,700r4
Axle/Gears: 3.55,2.73
While I prefer bc/cc you can get great results with single stage. It can be sanded and polished like a lacquer if it is a solid color, with metallics it is not possible as you will disturb the flakes and it will not look right.
Some of the new clears are simply amazing and that is what I use. It gives you some more material to work with if (heaven forbid) a scratch should happen!
I feel if you can do lacquer you can do bc/cc or single stage urethane. The thing to remember is that they chemically harden so read and follow the directions on pot life and flash time between coats.
I think you will be amazed how much more they build and "finish out" nicely, the chemistry has come a long way...
There is a huge difference in the hardness of some acrylic urethanes from one to the other so having some experience with one product does help.
Unlike lacquer you do not have to wait so long to start sanding too! HTH
Old Jan 27, 2010 | 02:56 PM
steve87ta's Avatar
Engine: 461,305TB
Old Jan 27, 2010 | 03:33 PM
steve87ta's Avatar
Engine: 461,305TB
Double Post
Old Jan 28, 2010 | 08:29 PM
58mark's Avatar
thanks for the great reply. I know what you man about the problem in working with a single stage paint with metallics. It took me quite a bit of trial and error to get good at painting my Dad's 58 with metallic Lacquer, but when I got the technique down, it was as good a paint job as you have ever seen
I am probably going to use BC/CC when I paint my Camaro. We did the 58 in lacquer for originality's sake, but I can't use that excuse for the camaro
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
