Rustoleum Rust Reformer
Old Feb 12, 2010 | 06:40 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Hey guys, I'm working on my 91 Trans Am convertible now
(https://www.thirdgen.org/forums/conv...t-serious.html) and right now I'm starting to work on some surface rust on my floors on the interior. There is surface rust in awkward and tight gaps and spaces that are almost impossible to sand, so to compensate I thought I'd try some Rustoleum Rust Reformer, in case I don't perfectly sand off every last speck. I'm just wondering if anybody tried this stuff and how it works. And the directions recommend applying the stuff between 50 and 90 degrees F.... you think its OK if its just a little under 50 when I go to put it on? Thanks!
Here's a picture of the can:
Old Feb 13, 2010 | 05:09 PM
sleepsinshed's Avatar
Car: 1988 IROC
Axle/Gears: 3:27 9-bolt
Re: Rustoleum Rust Reformer
I came across this stuff a few months ago and have been using it on everything. It lays down nice and has a good bond to the surface. I was using Eastwood's Rust Encapsulator before, but this is better stuff IMO.
I've used it at around 50 degrees without problem. Just takes longer to dry.
Old Feb 13, 2010 | 10:00 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
I have used the Rustoleum if you wont something that works then you need the eastwood brand just like the guy before said or you may find a brand called SEM rust mort in some auto part stores that I have used a lot and with good results good luck
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Fireslash
Apr 11, 2016 06:43 PM
FueledSoul
Sep 30, 2015 09:18 PM
tcflint
Sep 27, 2015 05:58 PM
