Removing a nice big dent
Old Feb 21, 2010 | 01:07 AM
FireInMe17's Avatar
Car: 1990 Camaro RS
Engine: 355 Vortec TPI LT4 Hotcam
Transmission: TH700-R4
This is a pic from the guy that I bought the car from, I don't know what happened, and neither does the guy I bought from, but I really want to get it pulled out of there, its starting to rust a bit so I'm thinking about just taking off the panel and popping it out and sanding the inside of it good to make sure its ok, but how would you suggest to get this out?
I tried once with a hammer laying on the ground reaching up into the car, but it wouldn't pop out all the way, only a little.
Old Feb 21, 2010 | 02:03 AM
firebird1992's Avatar
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
Re: Removing a nice big dent
fender are pretty cheap around here.
but get a dent puller with a slide weight on it and see if u can pull it out.
you could also get a bamhammer and just got BATSh*t on it lol worked for my car.
but i would just replace it are u planning on painting the car soon
Old Feb 21, 2010 | 09:27 AM
FireInMe17's Avatar
Car: 1990 Camaro RS
Soon is a few months away lol
So my best option would be to pull it out
Old Feb 21, 2010 | 10:28 AM
Drew's Avatar
See if you can find a paintless dent repair guy. You'll still have to deal with the scratches and rust, but unless you're a body man you'll only make it worse and it'll cost you more to fix it later. You'd be further ahead to pay to have the job done right, then to spend the same money on an aftermarket or junkyard fender.
Old Feb 21, 2010 | 01:02 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Thanks for the advice Drew, I just want that thing gone. All the outside needs its paint for the body and the wheels, its missing one peice of cladding on the door, and this dent, well a few small ones but that ones the worst one.
Vintageracer
Jan 10, 2020 05:33 PM
lt1z350
Aug 28, 2015 05:57 AM
kyleb24
Aug 15, 2015 08:24 AM
3rdgenparts
Aug 8, 2015 07:09 PM
