Can this bumper cover be saved?
Bought a 1991 Formula to add to my collection. It was involved in rear ending someone. I'd like to not have to replace the nose, however I can get a color matched one for ~380 shipped to me. So, the question is can this nose piece be saved and is it worth it? I've attached pictures.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Can this bumper cover be saved?
I'm no 'Bird expert, but $380 shipped sounds reasonable - esp color-matched. I paid $400 shipped for a non-color-matched 1992 Camaro nose.
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
It wouldnt be worth paying to have repaird but if you have a heat gun and time you could fix this bumper just heat small areas and get it stright and cool with a wet rag and $380 is a good price for a new one and this color is hard to match even if you have the car in front of you but to match a bumper that you cant even see well ???????
Good to know about the heat gun, because I do have one. Maybe I'll mess around on the weekend with it.
Car: Camaro 1987
Engine: V6 2.8l MPFI
My dad and my, have fixed a lot of bumpers of many bumpers like these with heat, its not a big deal.
It actually worked great. Used the heat gun and a damp cloth and pushed out almost all the dents. I'd say it's at about 90% good, which is good enough. The hard parts where the curves in the bumper. No paint blistering at all.
Glad the heating has worked. Keep and eye on it when the temp changes!
Last edited by overide; Oct 5, 2010 at 04:32 PM. Reason: wow guess I should ahve read down further! LOL
The color match was that it happened to be the same factory color as mine. Means the color was probably close enough given that the factory urethane bumpers don't match perfectly anyway.
I never once mentioned that it was new.
Car: '83 Camaro Berlinetta
Engine: 305 with aluminum heads, voodoo cam
Transmission: 700r4 auto
Axle/Gears: 10 bolt w/ 3.73 gears
whats the round peice bolted to the front of it? and theres no junkyards around u tht has one?
The round piece bolts to the front was a set of garbage fog lights that I removed.
I've seen one 91/92 Firebird in the yards around here in all my years of going, but it had gfx, so that didn't help me much.
The only ones we ever saw usually had GFX too, but they were destroyed. I always wanted to get the back bumper off a v6 or non-gfx car since it does not have the black bumper inserts that the earlier ones did and use to make my formula cleaner looking in the rear. I hate those freaking inserts!
Car: 86 T/A
Engine: 5.0 TPI
New2Chevy
Sep 28, 2015 12:35 AM
CAMAROBEAV
European Region
Sep 12, 2015 09:34 AM
