Bolt broken during hatch strut replacement
Old Mar 5, 2010 | 11:02 AM
3-Ball's Avatar
Car: 1984 Z28
Transmission: auto
Okay, so I go to change the hatch lifts on my '84 z28 and the head of the 8 mm bolt that holds the rear end of the hatch strut to the hatch breaks off. Because of the angle of the support block that it connects to I cannot drill it out. The strut is on the car and working but if someone accidentially bumps it then the strut will pop off. Does anyone have any ideas for keeping the strut on there if I cannot drill out what is left of the bolt? Thanks for your help.
Old Mar 5, 2010 | 01:18 PM
Jeromey Cummins's Avatar
Re: Bolt broken during hatch strut replacement
Id take another nut, flip it upside down, weld the head of the nut your using to the broke piece, then use a wrench to back it out. Might ruin the new strut, but least your able to put a new one one the way it should be. Hope this helps
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
transaero
Aug 31, 2015 01:14 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Fronzizzle
Aug 9, 2015 01:15 PM
