Lexan T-Tops?
Old Mar 17, 2010 | 10:23 AM
Nickz28ss's Avatar
Lexan T-Tops?
I have an 86 IROC-Z, im about to get a set of Lexan T-Tops, would the fit my car or am i gonna have to change the mechanism.
Im getting them either way, im just trading a set of stock 97 Dodge Ram rims and tires(no longer own the ram) so its no lose to me.
Old Mar 17, 2010 | 02:00 PM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Re: Lexan T-Tops?
Yes you will have to change out the locking mechanism but its relatively easy from what I heard.
FYI--The lexans are a step down from the glass--the lexans get scratched and tend to leak. There were alot of complaints to GM because of the leaking issue and GM was swapping out the lexan for glass.
Do a search and I think you will see what Im talking about..
BTW--welcome to the board!
Old Mar 17, 2010 | 02:14 PM
Nickz28ss's Avatar
Re: Lexan T-Tops?
alrighty, good to know. Ill look into it, but im still gonna get them, cause im just trading the stock rims and tires from my old ram i no longer own or have use for. There in mint condition, but i guess they'll be back up in case something happens to the glass ones.
Old Mar 17, 2010 | 03:08 PM
IMissMy86TA's Avatar
Car: 1991 Trans Am Vert
Engine: 5.0 TPI
Transmission: T-5 baby
Re: Lexan T-Tops?
They would be good for racing since they are much lighter than glass...
Old Mar 19, 2010 | 09:02 PM
hedberg667's Avatar
Car: 1989 GTA
Engine: 5.7 350
Re: Lexan T-Tops?
I got a set of Lexan t-tops for my 89 GTA and they went right in. I cant say what car they came off of since i got them from a third party. I eventually switched back to the glass ones since they didn't have any cracks and more importantly didn't leak
Old Mar 19, 2010 | 11:04 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Lexan T-Tops?
They'll fit with no problems. Even the ones with a larger diameter plastic pin that at first glance appear to require a change fit with no conversion required.
Lon
Old Mar 21, 2010 | 06:00 PM
Darth Satanis's Avatar
Car: 86 Firebird
Engine: Buick 3.8 V6 Turbo
Transmission: 200r4
Axle/Gears: 3.42's
Re: Lexan T-Tops?
Lon
Yup what he said. I have swapped several sets onto peoples cars (even had a set for one of my older bords for awhile) and the only thing I have had to do, is "Clock" the mounting holes
Old Mar 23, 2010 | 04:15 PM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Re: Lexan T-Tops?
Take it from me. I have the Lexan tops and if there is anyone who is silly enough to trade me for glass ones. I would do it. They scratch easy and they make a lot of squeaking noises. Mine dont seem to leak though.
Kevin
Old Mar 23, 2010 | 04:29 PM
92Firebug's Avatar
Car: 1992 Pontiac Firebird Base
Engine: 305 TBI
Transmission: 700r4, B&M shifter & shift kit inst
Axle/Gears: 3:23....10 bolt
Re: Lexan T-Tops?
Kevin
same here. mine are scratched and have no clear coat, and are cracked (but nothing broken and no leaks) but they work good until i get glass
Old Mar 23, 2010 | 04:31 PM
Nickz28ss's Avatar
Re: Lexan T-Tops?
I see, the set that came on the car are the glass ones. So i have both kinds now.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
