Paint code on 87 iroc?
Old Mar 17, 2010 | 02:04 PM
87irocz2887's Avatar
Can anyone tell me where i can find the paint code on my 87 iroc?
Old Mar 18, 2010 | 03:33 PM
STEWARDORNG's Avatar
Re: Paint code on 87 iroc?
YOUR OTION LABEL SHOULD BE IN THE CENTER CONSOLE AND WILL LOOK LIKE THIS.********
PAINT AND TRIM OPTIONS
Paint and Trim options are identified with different alpha/numeric codes in the
last position to identify the location or type of material. For example, upon
viewing the label below, we see a code of 90A at the bottom of the extreme right
column.when using the chart below to cross reference the code(90a - which falls
within the parameters of 00A - 99A) with the area, we find that the code (90A)
represents the accent stripe color used on this vehicle.
CODE AREA
00A - 99A Accent Stripe Color
00F - --- Floor Covering
00I - |99I -------- Interior Color
00K - --- | Auxiliary Top Colors
00L - 99L | Lower Body Color - Primary Color Truck
00M - 99M | Mid Body Color
00P - --- | Wheels
00Q - |99Q -------- Body Side Moldings(Modular)
00S - --- | Sun Roof Colors
00T - 99T | Vinyl Top Colors
00U - 99U | Upper Body Color - Secondary Color Truck
00X - --- | Interior Accent Colors(Big 4)
009 - |999 ---- | Seat Belt Module
00B - |99B ---- --- Fisher Body Design Levels(Cloth) |
00C - --- | Fisher Body Design Levels(Cloth) |
00D - 99D | Fisher Body Design Levels(Cloth) |
00E - 99E | Fisher Body Design Levels(Cloth) |
00G - 99G | Fisher Body Design Levels(Cloth) |
002 - 992 | Fisher Body Design Levels(Leather) |
003 - 993 | Fisher Body Design Levels(Leather) |
004 - 994 | Fisher Body Design Levels(Leather) |
00N - 99N | Fisher Body Design Levels(Vinyl) |
00R - 99R | Fisher Body Design Levels(Vinyl) |
|Service Parts Identification DO NOT REMOVE | |
|1 G 3|A R 4 7 9 X E 5 1 0 0 0 0 1 | |
|AG1 A|6 AU3 A31 A90 BMD B34 B51 B65 B85 B93 CD2 C04 C49 C60 | |
|C90 C|5 DF3 D3C D33 D64 E5Z E7D FFL F40 GG1 GW9 G60 G67 G89 | |
|JA1 J|4 K05 K15 K99 LV2 MW9 MXO NA5 NB1 NK1 NK3 N33 N67 GJW | |
|T87 U|3 U23 U35 V08 V10 WC3 WG2 YT9 Y56 01L 6PH|42B|42I|42Q ---
|42T|409|7PH 11A 90A |
|SCO # 253 PAINT LOWER BODY GM CODE 42 |
|LT GRAY FERN MET-1984 CUTLASS |
|COLOR DUPONT CODE 397-AB154 |
|FISHER CODE WA 8239 |
|FILLERS TO BE ARGENT |
-|SOL LACQUER WA-L0848 U0848 A7372 |42T| |42B -- -
| |PRINTED IN USA | PART NO. 14065987| |
| PAINT TECHNOLOGY | |EXTERIOR FISHER | | ------ -----
|DIS LACQUER - DISPERSION LACQUER| |WA PAINT NUMBERS| | | TRIM |
|SOL LACQUER - SOLUTION LACQUER | ---------------- | |COMBINATIONS|
|BC CC - BASE COAT/CLEAR COAT | -------- ---- ------------
|WATER | | VINYL TOP |
|ENAMEL | | COLOR |
-------------------------------- |IF APPLICABLE|
NOTE: FOR 1986, THE INTERIOR TRIM CODE AND VINYL TOP CODE WILL APPEAR ON THE
LOWER LINE WITH THE PAINT TYPE/PAINT CODE.
Frozer!!!
Jan 19, 2024 04:55 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
kah992
Aug 19, 2015 02:55 PM
mustangman65_79
Aug 11, 2015 03:17 PM
