Removing T-Top Weather Stripping
Old Mar 28, 2010 | 06:36 PM
DacMan's Avatar
Hey all,
I have been cruising for info on how to remove t-top weather stripping and can't find any threads on the subject. Is there any way to remove them easily? Also is there any way to remove them without ruining the gaskets?
Thanks, DacMan
Old Mar 28, 2010 | 06:42 PM
4valvemach's Avatar
Car: 04 mach1
Re: Removing T-Top Weather Stripping
They should be just glued in and I really dont think you can get them off without tearing them.Why are you removing them if they leak get new ones?
Old Mar 28, 2010 | 09:05 PM
DacMan's Avatar
No I'm repainting the car and want to get the t-top jams. Should there be a metal structure under them? Mine have this weird metal structure I think they glue to it, but I can't tell.
Thanks, Dac
Old Apr 3, 2010 | 12:33 AM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
I saw some weatherstripping remover spray from 3m at walmart/oreillys/autozone. Costs freaking 6-8 bucks if I recall though.
Old Apr 3, 2010 | 06:13 AM
DacMan's Avatar
I have a can of it, it was like 25 bucks! It doesn't work very well either in my opinion. lol. although I bet a spray would work better.
Thanks for the idea, DacMan
Old Apr 3, 2010 | 06:45 AM
Awesome-X's Avatar
Car: 87 Camaro
You might try heating it up, a heat gun or a blow drier would suffice. Might work lol
Old Apr 3, 2010 | 06:36 PM
DacMan's Avatar
Good idea,
Thanks, DacMan
Old Apr 3, 2010 | 08:17 PM
Carlos773's Avatar
Well post what worked best since I would like to not rip mine off when doing some rust repair.
Old Apr 3, 2010 | 09:04 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
x a gizillion
Old Apr 4, 2010 | 08:44 AM
DacMan's Avatar
lol, sorry guys but I ended up trying most everything last night on my passenger side and couldn't get them off. I didn't want to tear them, so there they sit. I'll just paint around em.
Sorry, DacMan
Old Apr 5, 2010 | 04:43 PM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
If they didnt leak then its probably best.
Kevin
Old Apr 5, 2010 | 06:18 PM
Capoeirista's Avatar
Car: 1987 Camaro
Engine: 305 LG4
if you have a heat gun and a chisel(like a wood working one) this works pretty good. you could substitute the chisel for a flathead screwdriver as well if you have nothing else. I just did the same thing cause I stripped the car to bare metal. Just take your time and you wont rip anything. Start at the back section and work your way all the way around the the a-pillar. Dont heat the rubber too much cause it will tear. You want to heat the surface and scrape underneath. Your painting the car so dont worry about any scratches where the weather stripping is anyway. your best to treat those areas with por 15 or someting while you have the stripping off anyway.
1992 Trans Am
May 10, 2023 07:19 PM
I'llrocya
Exterior Parts for Sale
Nov 11, 2015 05:45 PM
LittleFranks
Sep 17, 2015 12:22 PM
InfinityShade
Sep 5, 2015 06:38 PM
g.l.mos
Aug 22, 2015 12:02 AM
