Intake
Old Apr 13, 2010 | 10:29 PM
irocz3507's Avatar
Car: 1987 IROC-Z
Intake
question about shaker hoods...
Old Apr 14, 2010 | 12:02 AM
tekkitan's Avatar
Car: 87 IROC-Z
Re: Intake
Old Apr 14, 2010 | 12:10 AM
Shadow Z's Avatar
Car: Lots of 'em
Re: Intake
Why yes, shaker hoods. They are awesome. Shaker hoods have always been way more of a Mopar and Ford thing, if you catch my drift. They look especially good on 99-04 Mustang GT's.
But, if you really want your hood to shake.. Jump on it!
Old Apr 14, 2010 | 11:24 AM
irocz3507's Avatar
Car: 1987 IROC-Z
Re: Intake
true they do look good on mopar and mustangs but i just wanted to do something different with the camaro and I have never seen and 87 with a shaker hood so i figured i would just go for it...
Old Apr 14, 2010 | 04:30 PM
Shadow Z's Avatar
Car: Lots of 'em
Re: Intake
Well, if you try it, make sure you post some pictures. I wouldn't like to see that done on a Third Gen though. We have very good drag coefficients. Camaros have a drag coefficient of .34, and I believe the Firebirds are at .31 or .32. There's a guy on ecomodder who got his 1982 Firebird down to a .27 drag coefficient with some kind of "aero" wheels.
The farthest I will go towards messing up the low drag coefficients of a Third Gen are the SS hood. I love them, and they would not cause nearly as much drag as a shaker hood, which is designed to actually be functional.
Check out a few pictures of a Third Gen with the SS hood, you'd probably like it more than a shaker hood anyway.
Pictures below are from Hawks Third Gen Parts.
Old Apr 14, 2010 | 04:41 PM
aremy10's Avatar
Car: 91 firebird
Axle/Gears: stock
Re: Intake
one time and once only have i seen a third gen with a shaker. it was a 91 trans am with the bird emblem on the hood and all that. it looked AWESOME for the life of me i cant find anyone that makes a kit for this. but if you do find one , i would get it
Old Apr 14, 2010 | 04:43 PM
irocz3507's Avatar
Car: 1987 IROC-Z
Re: Intake
Yea,I can't say I know that much about the drag stats, but I've seen the SS hoods before but I've just never seem to like them. I either wanted to try something different or get one of the Daytona Turbo Hoods which would really be easier and i wouldn't have to mess with my carb or air filter. My engine sits real high and i had to get the lowest profile filter i could find to fit under the stock hood.
Old Apr 14, 2010 | 04:49 PM
irocz3507's Avatar
Car: 1987 IROC-Z
Re: Intake
I've never seen one, thats kind of why i wanted to do it. I have never been able to find a kit specifically for a camaro. I figured I would just buy a T/A kit and try it that way.
Old Apr 14, 2010 | 05:03 PM
aremy10's Avatar
Car: 91 firebird
Axle/Gears: stock
Re: Intake
my filter doesnt fit under the hood. ive had a few ideas though of what to do . heres one of them , let me know what you think;
cut the hood so the cleaner fits on ( obvious) im gonna fab my own scoop with a flange on it. so i can put a rubber seal aroung the flange,, and drill a few holes around the flange. what i would like to do that i havent seen in tgo, is make the scoop removable for nice days and just have the cleaner stickin out, but when the weather isnt as good i can easily and quickly bolt the scoop back on ,with either pins or wingnuts. on the hood i would like to put rubber gromets in the drilled holes to keep em from rusting etc . the only thing im worried about is it lookin cool. what do you guys think of this idea
Old Apr 14, 2010 | 07:48 PM
irocz3507's Avatar
Car: 1987 IROC-Z
Re: Intake
Sounds good to me, and as far as it looking cool, if your making the scoop i would just look at some scoops i already liked and just try to kind of make one similar to it. I also thought about getting one of the butterfly carb scoops. I really like the way they look, and as far as the hood work its not that bad.
Old Apr 14, 2010 | 08:19 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
Re: Intake
the thing about shaker hoods, is that the shaker box is not mounted on the intake, it bolts above the intake, feeds into some plastic and rubber ducting down to a filter box on the frame rail, then up into the intake, there are hols in the bottom of the shaker box and air filter box for water to drain out, your method will end up with water in the engine when it rains
Old Apr 14, 2010 | 08:47 PM
irocz3507's Avatar
Car: 1987 IROC-Z
Re: Intake
Oh, well thanks for that warning, I didnt think about that.
Old Apr 14, 2010 | 09:15 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: Intake
Well said bro. I would of never thought about that either.
Old Apr 14, 2010 | 09:33 PM
irocz3507's Avatar
Car: 1987 IROC-Z
Re: Intake
I guess the more I think about it the more problems I'm going to run into. I'm thinking its either going to be Turbo Hood or a butterfly vavle carb scoop...
Old Apr 14, 2010 | 09:37 PM
Re: Intake
Ive seen a turbo hood but instead of having the hood louvers, they put plexy glass. It looked tight man. You can see down inside the hood and view the plenum. I thought it was nice. But them Daytona Turbo hoods are nice IMO.
Old Apr 14, 2010 | 09:39 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Intake
theirs a thread someone did a shaker on a 3rdgen
Old Apr 14, 2010 | 09:42 PM
irocz3507's Avatar
Car: 1987 IROC-Z
Re: Intake
whats the post name?
Old Apr 14, 2010 | 09:48 PM
FueledSoul's Avatar
Re: Intake
https://www.thirdgen.org/forums/fabr...embly-mod.html
Old Apr 14, 2010 | 09:53 PM
irocz3507's Avatar
Car: 1987 IROC-Z
Re: Intake
thank you!
Old Apr 14, 2010 | 10:25 PM
irocz3507's Avatar
Car: 1987 IROC-Z
Re: Intake
i actually saw a picture of the plexy glass thing last night, and yea it really did look BAD A.
Old Apr 15, 2010 | 01:21 AM
Re: Intake
Was it a blue Camaro? If so, that's the one Im refering about.
Old Apr 15, 2010 | 02:58 AM
Re: Intake
OOps. It's been a while since I saw the Camaro with that Turbo hood. Well I found it and its not the plenum that you can see under the plexy glass, its the carb or TBI system that is visible. Anyway here is the link.... https://www.thirdgen.org/forums/post...90-post93.html
Old Apr 15, 2010 | 08:40 AM
irocz3507's Avatar
Car: 1987 IROC-Z
Re: Intake
Yea I saw the plexy glass hood on that blue camaro. But yea i freaking love the turbo hoods. If I do end up getting a Daytona Hood I'm totally going to do the plexy glass thing! I'm really undecided on it though. I really like the butterfly vavle carb scoop too though. I cant decide...
Old Apr 15, 2010 | 11:10 AM
Re: Intake
Do what makes you happy man. It is your car and you'll be driving her around. Heres a good solution. Just browse around for the style of hoods already on other Camaro's. Make a comparison from a few that you like and decide on which would make you more happy. Another option is if you have money to spend, buy another hood with the other feature that you like. Just switch the hoods out when you want to. That way you'll have 2 hoods that you like. Just a thought.
Old Apr 15, 2010 | 02:53 PM
irocz3507's Avatar
Car: 1987 IROC-Z
Re: Intake
I thought about doing and that and intend on doing that when have the extra money of course.
Old Apr 15, 2010 | 04:05 PM
Re: Intake
If I was able to push money out of my rear end, I would have 3 hoods; O.E.M. IROC hood with hood louvers, Daytona hood with louvers, and Daytona Hood with plexy glass see through. But I work at Target and haven't completed my degree of Computer Information Systems.
Old Apr 15, 2010 | 04:56 PM
irocz3507's Avatar
Car: 1987 IROC-Z
Re: Intake
understand that, i work at piggly wiggly and I'm bout to get my builders license. After I close on a house or two I'll really be able to do what i want with it.
Old Apr 15, 2010 | 05:03 PM
Re: Intake
Very nice. I think I envy you right now. I can already picture your wallet getting fatter and bank account adding up. Good luck irocz3507.
Old Apr 15, 2010 | 05:52 PM
irocz3507's Avatar
Car: 1987 IROC-Z
Re: Intake
Thanks but it will probly be more like my wallet staying the same sized and my car looking better and better. lol
Old Apr 15, 2010 | 06:54 PM
Re: Intake
... I Like Your Style Bro. It's kind of like some of us low income peeps that make the minimum wage, live in a run down trailer and dump all of thier income tax money on a new car instead of lookin for a house. No offense to anyone though, I use to live in a trailer park as a child. I admitt though that my wife gave me a choice, either buy a used reliable car, or fix up my junk (my IROC). Of course my reply was I'll stick to my junk.
Old Apr 15, 2010 | 06:55 PM
Re: Intake
shall we?
Old Apr 15, 2010 | 09:35 PM
87bluebird's Avatar
Car: 1987 pontiac firebird
Engine: 6.5 turbo diesel
Transmission: t56
Axle/Gears: Ws6 axle
Re: Intake
could you take the intake and scoop off of a second gen put it on your engine and then just cut a hole in your hood for it. thats what i was thinking of doing.
Old Apr 15, 2010 | 09:54 PM
irocz3507's Avatar
Car: 1987 IROC-Z
Re: Intake
Shoot, I'd live in my car before I would sell it! But anyways as for taking a shaker off a 2nd generation and puting it on there, thats what i wanted to do in the first place I just didnt know if it would all fit right. I just wanted to add a little old to the new.
Old Apr 15, 2010 | 10:00 PM
87bluebird's Avatar
Transmission: t56
Re: Intake
the only problem with that that i know of is that the engines our cars are offset to the side a little bit.
Old Apr 15, 2010 | 10:04 PM
irocz3507's Avatar
Car: 1987 IROC-Z
Re: Intake
well I don't know if I would want to put it in there if its real bad off. It just depends on how much off it is.
Old Apr 15, 2010 | 10:06 PM
irocz3507's Avatar
Car: 1987 IROC-Z
Re: Intake
How bad off are they or does it depend on whats in it?
Old Apr 16, 2010 | 06:13 AM
87bluebird's Avatar
Transmission: t56
Re: Intake
there not that far offset only a couple of inches you could probably modify the scoop so it sit in the center of the hood
Old Apr 16, 2010 | 07:28 AM
irocz3507's Avatar
Car: 1987 IROC-Z
Re: Intake
Thats what I would probly end up doing, ive just never noticed that before,
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
