Anyone used rubberized undercoating?
Old Apr 14, 2010 | 10:25 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I have the trans out of my car now and was thinking about spraying the underside of the car with this. It isnt anything special, just the stuff you can get at discount. Its not the bedliner stuff either. Just seeing if anyone has used this to try to dampen some of the road noise and to make a more durable coating than just paint.
Old Apr 14, 2010 | 11:18 AM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Re: Anyone used rubberized undercoating?
I've never used it myself but I've heard that the coating can crack and harbor moisture. Not sure if it's true but sounds possible to me. Just something to think about.
Alex
Old Apr 14, 2010 | 01:07 PM
Jekt's Avatar
Car: 1983 camaro
Engine: 350 soon to be 355
Fueledsoul has but i cant seem to find the pics now
Old Apr 14, 2010 | 04:18 PM
86TA355SR's Avatar
Car: 88, 89 & 91 GTA
Engine: 355 Super Ram/350
Transmission: TH-375/700R4
Axle/Gears: Currie Ford 9"/3.70
There was a post in the restoration/history board about someone using "Herculiner". Same thing as Rhino Liner for truck beds, looked good when he was done.
I've used the rubberized undercoating and wasn't impressed. Spent a lot of time doing prep work for it, and it cracked. Plan on using the Herculiner next time.
Good luck
Old Apr 14, 2010 | 04:22 PM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
i've used it with great success ....need to get a quality brand....like 3M or similar..also spray it in realtively thin layers so when it "shrinks" it doesn't crack.....works great in wheel wells after you've painted a car and there's overspray you want to cover up...
Old Apr 14, 2010 | 06:33 PM
built91Z28's Avatar
Does it actually help with road noise?
Old Apr 14, 2010 | 07:21 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
I used it in the wheel wells of my car and liked it. It definitely kills noise, although my tests have only involved knocking on the metal since the car hasn't seen the road yet.
If you are looking for a durable coating to protect the underside of the car, I would suggest bed liner. You can get it in spray cans and it is much more durable than rubberized undercoating
Old Apr 14, 2010 | 08:45 PM
hotrodln's Avatar
Engine: Lt1 in IROC
i think it does deaden noise....i would like to try the bed liner material next time....i've got an 08 CTS with NOTHING under it....the bottom of the car is all just painted steel....i might try the bedliner spray on that......
Old Apr 14, 2010 | 08:54 PM
built91Z28's Avatar
Thats what I was wondering.
Old Apr 15, 2010 | 06:56 AM
Jekt's Avatar
Car: 1983 camaro
thats what im planning on to a spray on bed liner
Old Apr 15, 2010 | 08:43 AM
da.slyboy's Avatar
Car: 84 frankenstein Z28
I would also stay away from using cheap undercoating. I used it both on the underside of my Camaro and truck (before I knew better) and even with proper prep water gets behind it and creates a great place to harbor rust. If anything I would suggest laying down a good sealant before adding the undercoating.
Old Apr 15, 2010 | 08:45 AM
hotrodln's Avatar
Engine: Lt1 in IROC
i like the idea of the bed liner material, but how do you apply it? do you need to buy a special gun to spray it? is it a two part liquid?
Old Apr 15, 2010 | 08:49 AM
built91Z28's Avatar
If I do the spray on bedliner, it will be in a spray can like spray paint. I'm sure there are better versions, but I dont have money for them. Plus I live in Florida so I'm not as worried about rust as some of you northern people.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
loud91rs
Oct 5, 2015 10:05 PM
Gordonr1973
Sep 29, 2015 11:59 AM
gta_knight
Sep 23, 2015 04:59 PM
