***REAR END DAMAGE REPAIR***
Old Apr 25, 2010 | 02:15 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
ok i'm gonna start fixing the damage on my 89 iroc-z but i'm wondering if there's gonna be any interest on this thread so please reply and let me know if you guys want me to keep posting my progress on it on a "HOW TO" type of thread
this what i would be covering if INTEREST IS SHOWN:
how to:
decide were to make your cuts
cut damaged panel
prep panel to be welded
overlap and fuse panels together
general body work
reseal seems
*maybe* straighten supports
proper way to fix plastic bumpers (bumper from jnkyard might need work)
fiberglass
and probably more along the way
i'll leave it under the discretion of the MODS to either lock or delete this thread if no interest is shown.....
here is what the damage is:
Old Apr 25, 2010 | 02:30 PM
DyingYoung138's Avatar
Car: '86 Trans Am
Engine: 305 H.O.
Re: ***REAR END DAMAGE REPAIR***
Looking forward to seeing the process. Post plenty of pics.
Old Apr 25, 2010 | 02:52 PM
Gregs_GSXR's Avatar
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
any rear frame damage ? suspension damage? axle bent? is it all cosmetic ? looks like a lot of work, but yet again looks like sail panel, inner fender, rear bumper taillight, and some metal work to the trunk floor and corner. Good luck. it looks like an easy fix, but take the time do it right, great prep work makes for a great finish product... dont forget pics too
Old Apr 25, 2010 | 03:51 PM
juanillox8's Avatar
Car: TOO MANY
mainly cosmetic most of the panels will be replaced I WILL take lots of detailed pics... hope you guys benefit from this thread...
Old Apr 25, 2010 | 05:12 PM
Bowtiebruiser's Avatar
Car: 1982 Camaro Z-28
Engine: 350 4bbl
Transmission: Borg Warner Super T-10
Axle/Gears: Richmond 10 bolt 4:10 Posi
I for one am looking forward to it(there no telling what terrors lay under my primer) and being a former body man myself it may jog my memory
Old Apr 25, 2010 | 06:31 PM
MI ROC-Z's Avatar
Car: 89 IROC-Z
Engine: L98 5.7 liter
Transmission: TH700r4
Axle/Gears: limited slip 3.23
I'll be watching your rebuild, Good Luck.
Old Apr 26, 2010 | 08:04 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Heres a link to Fyrchickens quarter panel replacement on his ride.
Excellent description and great pics of the whole process from start to
finish! A must read for anyone!
https://www.thirdgen.org/forums/body...ter-panel.html
Old Apr 26, 2010 | 12:28 PM
MärkJ's Avatar
Car: '88 Pontiac T/A
Engine: 305ci
Axle/Gears: LSD
Looking forward to seeing this. Hope it all goes well for you.
Old Apr 26, 2010 | 07:47 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Consider me interested!
Old Apr 26, 2010 | 08:27 PM
juanillox8's Avatar
Car: TOO MANY
AAALLLL RIIIIGHT THANX guys i just wanted to find out there were people interested on something like it i will be posting alotta pics and i will be detailed step by step... since im taking my time to fix it right bare with me please....
I'll keep u all posted
Old Apr 26, 2010 | 09:10 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
bump.....good luck
Old Apr 26, 2010 | 09:28 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
You beat me to it! Although, I didn't have to replace the inner panel. All the damage on that car was external. It's A LOT of fun...
There is a factory seam at the top of the sail panel that I cut on. If you sand the paint off to bare metal you can see it very easily. Everywhere else I suggest drilling out the pinch welds. If you do that then it will all come apart relatively easy...except for where it has the adhesive.
Old Apr 26, 2010 | 11:36 PM
juanillox8's Avatar
Car: TOO MANY
ya i know spot weld drill bit its my girlfriend and for the parts with seem sealer wire brush wheel and air chisel are my helpers lol done this dozen times its gonna be easy but i wanna do the write up very very detailed for people to get something out of it.
Old Apr 27, 2010 | 02:14 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Im interested.
When are you gunna start tearin into it?
Old Apr 27, 2010 | 04:21 PM
F-bodiesforever's Avatar
Car: 1989 Pontiac Firebird
Engine: 2.8L V6
Transmission: Stock
Axle/Gears: Stock
wow. I have an 89 firebird with rear end damage too just about as bad too let me know how it works out for you
Old Apr 27, 2010 | 08:24 PM
juanillox8's Avatar
Car: TOO MANY
Originally Posted by bradley23150
Im interested.
im gonna start chopping it on friday after work..
Old Apr 30, 2010 | 06:16 PM
NT-Z's Avatar
Car: Had 2 iroc-z's . An '87 & '88.
Engine: HAD 5.0 & 5.7 tpi
Axle/Gears: stock
ill be into it. Always love seeing camaros gettin fixed up and put back on the road instead of parting and crushing them.
good luck! looking 4ward to pics
Old Apr 30, 2010 | 08:50 PM
juanillox8's Avatar
Car: TOO MANY
and the fun begins
this is the tool used to drill the spot welds out:
when drilling spot welds you gotta be careful not to go all the way through the first couple times you might do it but after a while you get use to feeling the drill bit cutting through each individual panels so you just fill when you drilled the first layer.
Old Apr 30, 2010 | 08:58 PM
juanillox8's Avatar
Car: TOO MANY
My initial cutting will be right here to get the old qt panel out of the way but it will probably be my joining point also...
BUT WHY THERE AND NOT HIGHER WHERE THE OG SEAM IS? many of you might ask
well it has a simple logical explanation but i will explain why when i get the new panel in place
Old May 1, 2010 | 06:35 PM
juanillox8's Avatar
Car: TOO MANY
this is the donor vehicle.... NO OFFENSE but this is the only thing Camaro rs v6's are good good for (donating their organs)
now you see it
now you dont
Old May 1, 2010 | 06:39 PM
juanillox8's Avatar
Car: TOO MANY
its easier to cut the majority of the panel with a a sawzall (without damaging reusable parts) and then trim the small pieces left behind to clean up and get it ready for the new panel to go in. i separated the spot welds with an air chisel, its faster easier and, MAN U GOTTA LOVE THAT NOISE!!!!!!!!
Old May 1, 2010 | 08:29 PM
Engine: LB9
Am I the only one who can't see the new pictures?
EDIT: never mind thanks for fixing that lol
Old May 1, 2010 | 08:31 PM
I saw em' yesterday, but now I cant.
Old May 1, 2010 | 10:48 PM
juanillox8's Avatar
Car: TOO MANY
i apologize i had the album on private lol sry.
Old May 1, 2010 | 10:58 PM
juanillox8's Avatar
Car: TOO MANY
enough for today ....after 2 hrs in the junk yard and 4hr workin at home the iroc its ready and waiting for the new panel to go in heres how it looks right now
total hrs so far: 7.5
total $ invested : $87.50
Old May 2, 2010 | 12:46 AM
L0tuS's Avatar
looking good, did you put the car on a frame machine at all to get to pulled straight again??
Old May 2, 2010 | 01:02 AM
Sonymaster20's Avatar
Car: 1992 Rs
Engine: 305 TBI
Transmission: 5-Speed
Axle/Gears: 3.08
I was gonna say the same thing I would have had that thing pulled instead of just cutting it all up but it looks like you know what your doing
Old May 2, 2010 | 04:31 AM
L0tuS's Avatar
you should always get the car checked before cutting, i have to do the same thing to my firebird that got hit way less and iam still having the frame measured so nothing comes back for a surprise.i also wish people would be nice enough to hit your car so that you could just buy the aftermarket skins and not do the work twice.
Old May 2, 2010 | 09:24 AM
juanillox8's Avatar
Car: TOO MANY
i checked everything before cutting the car didn't have any frame damage, any time a car gets hit to that point it shows it right away ( doors are crooked, frame rails buckled, unibody supports shows damage etc) since i own two camaros i compared every single measurement, joint factory shapes b4 deciding where to cut, i did pulled a little with a comealong just to release some stress from the metal but IM 1000000000000% sure it didnt required the use of a frame machine .
Old May 2, 2010 | 10:53 AM
juanillox8's Avatar
Car: TOO MANY
time to prep the new panel
in some cases you get better results if you weld inside the car, its esier to work and it looks cleaner on the outside so that means lesssssssssssss cosmetic work ...
Old May 2, 2010 | 11:03 AM
Lookin real good!
And this car came with a PBR rear?! Hell of a deal for $500.
Old May 2, 2010 | 11:10 AM
juanillox8's Avatar
Car: TOO MANY
here are some pics of the wheel well if you look closely you'll notice they're not joined together by spot welds like the rest of the panels
the red line shows where gm welded all the way down to join the outer and inner wheel well.... the blue line and circles show where i will weld... i will be drilling wholes on the inner wheel well of the iroc and where the blue circles are and weld it from the inside and then the contour line will be welded from under the car
i decided not to separate the outer wheel well from the quarter panel, instead im gonna wild it together to the unibody of the car, that saves time and work and you end up with a factory looking wheel well edge without using any bondo to cover the welds
this is what i got so far:
Old May 2, 2010 | 11:15 AM
juanillox8's Avatar
Car: TOO MANY
Lookin real good!
heeeeeelllll yea and i stiiiillll can't believe it lol
Old May 4, 2010 | 08:10 PM
juanillox8's Avatar
Car: TOO MANY
the air compressor i was using gave up on me, i guess couldn't handle my tools lol guess i need to go get mine after all... so i'll update soon as i get it.
Old May 23, 2010 | 02:28 AM
Chrome on Rust's Avatar
Car: 89 RS
Engine: 305 TBI
We Want More!! Get your air compressor all ready
Old May 24, 2010 | 12:22 AM
Car: 1992 Rs
Engine: 305 TBI
Axle/Gears: 3.08
Indeed looking forward toward an update
Old May 31, 2010 | 08:38 PM
juanillox8's Avatar
Car: TOO MANY
IM sorry guys i had to stop project CALIFORNIA dmv wont let me get it back on the streets, when the insurance got involved they notified dv that it was only gonna be used for parts and wouldnt be fixed so they wont let me fix it so i will be using some parts on my z28 and the rest i will sell, if any of you is looking for something let me know...
SOOOOOOORRRRRYYYYYYY
Old May 31, 2010 | 09:14 PM
87bluebird's Avatar
Car: 1987 pontiac firebird
Engine: 6.5 turbo diesel
Transmission: t56
Axle/Gears: Ws6 axle
wow that is such a shame. you obviously know what your doing and would have fixed it rite.
Old May 31, 2010 | 09:17 PM
juanillox8's Avatar
Car: TOO MANY
yea too bad previous owner didn't know how to deal with the insurance and dmv WOULD let me get it back on the street but the fee is outrageous thats why they said they cant do it
Old May 31, 2010 | 09:55 PM
That seriously sucks.
Old May 31, 2010 | 10:04 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Talk about an extreme bummer I was thuroughly enjoying this write-up just incase I ever had a fender bender. but thats OK since between frychikin and you there was great information. Thanx anyway
  #42
Camaroguy6984's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI L03
Transmission: TH700R4 Corvette servo
Axle/Gears: 10Bolt 2.73
interesting, ill keep watching
Old May 31, 2010 | 10:17 PM
  #43
juanillox8's Avatar
Car: TOO MANY
yup i was freaking mad... i apologize to all of you.... on the bright side im gonna start fixing the nose on my car so i will make a detail write up of how to fix the stress cracks on it and i know thats a very common problem thats why ill make a thread bout it
Old May 31, 2010 | 10:43 PM
  #44
WOO HOO !! Just the other stuff I need
Old Jun 1, 2010 | 12:16 AM
  #45
Duane's 91 Z/28's Avatar
Car: 1991 red Z/28
Transmission: T5 swap
What a bummer. I'm sorry to hear about your run in w/California DMV. California sure loves to rake people over the cliff!!
Old Jun 1, 2010 | 12:21 AM
  #46
juanillox8's Avatar
Car: TOO MANY
yup and i don't know if you know but now they lower the emissions standards for cars ours age they sure want to take cars out of the street because of the "environment"... my a**.... yea the environment of money thats is...
morrow
Jan 13, 2024 12:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
buckshot63
Interior Parts Wanted
Sep 3, 2015 08:10 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
