upper door pin... help
Old Apr 28, 2010 | 08:35 PM
89fbrestor's Avatar
Car: currently 91 camaro
Engine: soon to be 350 turbo
Transmission: soon to be 4l80e
Axle/Gears: 99 ss rear end with richmond 4:11's
does anyone know where to find the upper door pin. the only place i can find it is hawks and they want around a 100 bucks
Old Apr 29, 2010 | 09:42 AM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Re: upper door pin... help
Those are expensive and I have seen them other places but not for cheaper. I dont know why they are so much.
Kevin
Old Apr 29, 2010 | 03:52 PM
89fbrestor's Avatar
Does anybody else have any other place i can go,or know of a place that sells them cheaper?
Old Apr 29, 2010 | 06:59 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Don't know the prices, but I'd check www.top-downsolutions.com
Old Apr 30, 2010 | 02:54 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
There is no conventional "upper door pin"... They are short pins and bushings. Two separate pins and bushings. I dont think they are servicable.
If you want to make it better than factory, order a set of the greasable bushings. You can get them greaseable, or non-greasable.
Im pretty sure TDS sell them, along with anything else you'd need to restore your door to proper function.
here's what the kit looks like. Does the upper bushings and the lower pin. Its pricey, but you'll never have a sagging down again, and they'll close like butter.
J.
Old Apr 30, 2010 | 03:09 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
I replaced both sides in my Z with the greaseable units sold by Top's Down. That's the right thing to do, if you want it done right. Sure the parts arent cheap but, either is a good night out on the town. Do the right thing and order the kits from Lon.
Installation takes a few hours + per side. If you have a engine hoist, use it to support & lift the doors. Instructions of the proceedure are included with the kit. However, I did use a grinder with a carbide tip to open up the bracket for the new collars.
It's money and time well spent. You'll never have to do this job again, unless others ask you to do it for them...
Good luck
Old Apr 30, 2010 | 09:09 PM
89fbrestor's Avatar
thanks for the info guys well taken.
brian
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
ivan1137
Sep 23, 2015 09:08 AM
tsfso59
Exterior Parts Wanted
Sep 9, 2015 09:09 AM
