Rear Body Panel Help -any one cut one out before
Old May 4, 2010 | 12:59 AM
andyda98's Avatar
Car: 1988 and 1989 IROC_Z
Engine: 350 TPI w/ chip & 305 TPI
Axle/Gears: 2.77
Has any one cut one of these out before and put a new one in? Quarters are fine just the rear panel is messed up
My 1988 iroc was hit in the rear end, "lightly" lol and smashed out the glass tail lights bumper cover and every thing behind it pushed it in a little. The only thing that it seems to need is the rear body panel and every thing that plugs into it. And maybe a rear fender pulled just a little. So i am looking for any one who may have replaced this part and if so, how hard is it .
It looks like i would have to cut said part from another car and weld it back in since they dont sell them any were. Can any one help me with this one.
thanks
nothing found in the forums for this while seaching
Attached Thumbnails Rear Body Panel Help -any one cut one out before-100_0579.jpg   Rear Body Panel Help -any one cut one out before-100_0580.jpg   Rear Body Panel Help -any one cut one out before-100_0581.jpg
Old May 4, 2010 | 01:27 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: Rear Body Panel?
I do believe there is a tutorial already started... search and you shall find...
Old May 4, 2010 | 02:15 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
thanks
https://www.thirdgen.org/forums/body...ge-repair.html
im in the process on doing that, i just need to find the part if you have it already i can guide you through it but ill need pictures and you need to do all the pulling you can before taking that panel off of ur car
Old May 4, 2010 | 03:48 PM
andyda98's Avatar
Axle/Gears: 2.77
some more pictures
Attached Thumbnails Rear Body Panel Help -any one cut one out before-100_0576.jpg   Rear Body Panel Help -any one cut one out before-100_0577.jpg   Rear Body Panel Help -any one cut one out before-100_0578.jpg
Old May 4, 2010 | 08:06 PM
juanillox8's Avatar
Car: TOO MANY
your gonna need to either weld tubing or if you have a porto power to put it from qt panel to qt panel because once you cut that sucker they will collapse inward... after u du so start drilling the spot welds, get urself a spot weld drill bit
Old May 8, 2010 | 11:31 PM
andyda98's Avatar
Axle/Gears: 2.77
Re: Rear Body Panel Help -any one cut one out before
bump
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
BlackBoulder
Aug 11, 2015 11:15 PM
Exxon Limited
Aug 9, 2015 08:13 PM
z28addict8490
Aug 7, 2015 08:48 PM
