Need opinions for a few small problems
Old May 12, 2010 | 01:43 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Is there supposed to be a seal along the bottom edge of the glass for the hatch? I highlighted the area I'm talking about in one of the pictures.
I also wanted to know what size screws I should use to bolt the weather strip in the picture. I am missing one of the screws I need and do not know what size was originally in there. I'm missing the screw in the center of the weather strip (the hardest to screw in because the window sits highest there.) I also have a problem with that weather strip sitting too far from the window but I might just have to adjust the window or something to make that work.
Last question is what I should do about a third brake light. I switched spoilers unaware that I would lose my third brake light doing so, and I want to put one in. What would be the best way to do that?
Attached Thumbnails Need opinions for a few small problems-0429001711.jpg   Need opinions for a few small problems-0429001711a.jpg
Old May 12, 2010 | 01:53 PM
firebird1992's Avatar
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
Re: Need opinions for a few small problems
clear silicone for the hatch
and the weatherstrip is a 7 or 6
mines was 6mm and 7mm one after the other
Old May 12, 2010 | 02:12 PM
Mr Froman's Avatar
I can not figure out how am I going to get that screw in without removing the window.
Old May 12, 2010 | 02:14 PM
Car: 1992 firebird
Engine: V6
roll the window all the way down and remove the inside door cover.
or get a socket or bit with an elbow
Old May 12, 2010 | 02:55 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
I couldn't get a socket in there at all..
But thats the way to do it, remove the whole inner door panel, there are two metal felt covered tabs that push outwards on the glass to hold it in place. If you loosen the bolts on those tabs (or just take them off) it'll let the glass move around in the door a little and give you some clearance to put the screws for that trim in.
Old May 12, 2010 | 03:10 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Maybe something in the following link:
https://www.thirdgen.org/forums/body...-shortcut.html
JamesC
ZMWojnar
Brakes
May 12, 2019 10:43 PM
theshackle
Mar 5, 2017 06:37 PM
camaro71633
Sep 1, 2015 10:24 AM
Thornburg
Aug 25, 2015 01:46 AM
db057
Aug 22, 2015 08:17 PM
