DAMNIT
Old May 18, 2010 | 08:52 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
DAMNIT
Ugh, I just realized that I forgot to reinstall those two bars that make an "x" in front of the radiator before I put the whole nose back together on my 91 Trans Am. Are they important/what are they for? You can see them in this picture:
Thanks!
Old May 19, 2010 | 03:18 PM
Camaros4Life's Avatar
Car: 84 Camaro
Engine: 350 punch out .060 to 360ci
Transmission: 700R4 worked
Axle/Gears: 410 Posi
Re: DAMNIT
its suppose to be for cross support in the front of your car. i removed mine to put in an aftermarket fan, it does add to the support but it is not needed. if you want put the corner supports on the inner corners of the fenders.
heres a picture, i know its not our generation of car but its the same aspect.
hope this helps
Old May 22, 2010 | 09:51 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: DAMNIT
you should be able to slip them in from the top or bottom, and the bolts are pretty assessable.
sogabe
Jun 16, 2006 01:09 AM
ScrapMaker
Car Audio
53
Oct 22, 2005 11:57 AM
acescarrsRS
Pacific Region
16
May 27, 2004 03:25 PM
ChrisFormula355
South West Region
May 6, 2004 02:43 PM
RS'er
Feb 19, 2002 11:14 PM
