front clip removal?
Old May 25, 2010 | 10:54 PM
algershick's Avatar
front clip removal?
Upon removing a fender from my car I discovered why there is a strange gap between the hood and bumper that I can't close-- one of the supports under the fender has been hacked up and POORLY welded back together, off center.
I was at a wrecking yard recently and inspected a 3rd gen with all of the front sheet metal removed, and I didn't see any bolts or mounting hardware whatsoever between the front clip and the body. Can it be removed and replaced without cutting?
I know I'm probably going to hear "just get another body, they're a dime a dozen" but if at all possible I'd prefer not to. Berlinettas aren't terribly common around here and I have most of the electronics functioning properly!
Old May 25, 2010 | 11:10 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: front clip removal?
camaros are unibody cars which means the body is the frame. the fenders, hood, and bumper all bolt to the unibody. there is a subframe in the front underneath the car.
Old May 26, 2010 | 12:22 PM
algershick's Avatar
I know it's a unibody. I have a 63 Nova that is also a unibody; but the entire front clip unbolts, leaving nothing forward of the firewall. My question was if it's possible to do the same to a 3rd gen F body.
Old May 27, 2010 | 03:53 PM
sleepsinshed's Avatar
Car: 1988 IROC
Axle/Gears: 3:27 9-bolt
These cars do not have a sub-frame like earlier generations. All of what you see in the picture below is part of the body and cannot be removed by unbolting, it needs to be cut. The only thing that's bolted on is the K-member.
Old May 28, 2010 | 11:15 AM
algershick's Avatar
Thanks for the info!
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
anesthes
Mar 10, 2016 10:35 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
