Painting over POR15?
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Can you do this or should I get all the old paint off? I'm pulling the motor/trans probably this weekend to start the little bit of body work I need to do in the engine compartment and then I am going to paint it. Just the engine compartment for now. Right now I have POR15 on top of the factory paint. If I paint on top of this is that too much? I want this to look very good when I am done.
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Painting over POR15?
POR-15 should be covered if the area sees any kind of sunlight, else it'll eventually fade and discolor. My rollbar faded after a few years and it had 2 or 3 coats of Por-15 black gloss. They make Chassis Coat that works pretty well. I painted that over my factory paint in the engine bay. Came out well except for the places I got sloppy and had a few runs.
The black paint you see in my sig pic is the POR15. I am painting the engine comparment with actuall car paint now. I am doing a metallic blue. I just need to know if I need to get all the old POR15 off.
Engine: 383 SBC
Pretty sure they give directions on the PorShop website for painting over the top of it. If it's clean enough and isn't chipping or peeling I wouldn't think there would be any problems.
Engine: 383 SBC
PRIMING OVER POR-15:
Use POR-15 Tie-Coat Primer after POR-15 is dry, following directions on can. Tie-Coat Primer may be sprayed or brushed in multiple coats if desired. Sands to a perfect finish.
http://marine-paint.com/por-15-faq.htm#primover
Cool, thank you. I dont know if I'm going to buy their primer, but this might save me a lot of sanding.
Hotrodboba400
Dec 10, 2019 07:07 PM
1Aauto
Sponsored Vendors
Sep 13, 2017 12:58 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
