What tools do I need to take???? HELP
Old Jun 3, 2010 | 12:29 PM
leedavidalan's Avatar
Hey guys, I'm going to the junkyard again tomorrow. I want to get the following:
1) Door handles
2) Door panels
3) Arm bar thingie (attached to door panels)
What tools will I need to remove all of these items???
thanks SO MUCH for all your help fellas!!!
Old Jun 3, 2010 | 12:47 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Re: What tools do I need to take???? HELP
Bring an assortment of torx bits, metric wrenches, an interior trim removal tool (or really large flat blade screwdriver, but the tool is cheap and works a lot better!), and if it has manual windows a window crank removal tool.
Just going off of memory here, i think the armrests are held in place by 3 torx bolts around a T-30 size. The interior door handle trim (and power lock trim if it has that) is a smaller torx bit size, like a T-15 or T-20. Some of the "bolts" around the door handle are fake ones molded into the plastic, be careful not to try and remove those! The whole interior door panel is attached with plastic push in clips, if you have the tool to remove interior trim you'll probably be able to get them out without breaking the clips or pulling them out of the door panel. The outer door handle is held on with two 10mm nuts, you'll need the window up (or out of the door) in order to reach it, just pop the window crank back on if its got manual windows. Not sure how you'd do it if its got power windows. If you're getting the window seals you'll need a 7mm wrench to reach them.
92projectcamaro
Dec 8, 2015 12:25 AM
tyeo098
Nov 30, 2015 06:27 PM
Reid Fleming
Oct 10, 2015 09:56 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
