84 T/A Fender
Old Jun 18, 2010 | 09:17 AM
JCherwien's Avatar
Car: 1984 Autoform Firebird
Engine: 2.8l V6
84 T/A Fender
Greetings All,
Question for you knowledgeable people out there...
I need to replace the Fenders on my '84 Firebird, and have been trying to located T/A Fenders to place on there...So far I've gotten a hold of one really nice NOS 84 T/A Fender for the Driver side, but haven't had that much luck on the passenger.
Here's my question...there are tons of them available for the 85+ T/A style - Are they close enough that I could drill/fill the holes for the GFX mounts without too much of a problem, or are the Vent mounts/standard mounts different as well?
Thanks!
Miah
Old Jun 18, 2010 | 12:20 PM
Blackknight's Avatar
Re: 84 T/A Fender
the fenders are all the same you can get any year from 82-92. I would just get two from the same car if you can.
Old Jun 18, 2010 | 04:40 PM
Pocket's Avatar
Car: 91 Trans Am
Re: 84 T/A Fender
Factory verts have a different lower mount in the fenders to accommodate the stock SFCs
84 would be aftermarket so its no guarantee the fenders will interchange with a standard 82-92
Old Sep 23, 2011 | 11:23 PM
fellro's Avatar
Re: 84 T/A Fender
I know this is an old post, but wanted to add to it for others like myself that will be searching for answers on this type question. I was reading about this same thing, and had seen some that say the older vents will not fit, but I recently picked up an NOS fender for the 85 and newer, and I did a trace to see what the difference is, and for the most part, there is none, except on the front side, there is two little tabs that perhaps might cause a little trouble getting the vent to sit in right. Otherwise, the trace was an exact match. There are 5 holes that the newer Trans Ams use for ground effects that the 82-84 did not, and 3 holes for the 82-84 that will have to be drilled.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
jovibuilt
Oct 18, 2015 08:12 PM
2012sergen11
Oct 13, 2015 07:38 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
