t top question?
Old Jun 27, 2010 | 09:06 PM
Matt S iroc's Avatar
t top question?
i just bought a rs today,when i was working on getting the cooling fan to operate it started pooring down rain.the t tops leak pretty bad so when it stopped raining i popped one off and i noticed that the bar is rusted and going to need replaced.what all it involved in changing it and how much of a pain in the *** is it going to be?
Old Jun 27, 2010 | 09:21 PM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Re: t top question?
The pain in the *** is the $ to replace it. How badly is it rusted? If hole causing rusted then yea it needs to be replaced. If I recall all that is required is removing the screws and then prying it off.
People want a pretty penny for an unrusted t-top bar, so like a broken record, Go yard hunting before resorting to buying one online. Hunt Craiglist for a days as well. They go for around $55-100 on here if I recall.
Old Jun 28, 2010 | 09:36 PM
Re: t top question?
cool thanks for the info.yeah it needs replaced,if it just had some surface rust id just sand prime and paint it but its bad off.the t tops leak so bad that i gotta replace the headliner as well.so i suppose that its not welded just bolted or screwed?
Old Jun 28, 2010 | 09:45 PM
z28_87Camaro's Avatar
Car: 1987 Z28 / 1988 IROC-Z
Engine: 305 LG4 / 305 LB9
Transmission: T5 5spd
Axle/Gears: 3.42 / 3.08
Re: t top question?
Welcome to the Thirdgen world, and the world of leaky Thirdgen's. It happens to the most of us with T-Tops. Enjoy your ride!!
Old Jun 29, 2010 | 12:28 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: t top question?
Best bet is to find a rust-free one from a junkyard -- I scored a perfect one off a car for $2. Good luck!
Also, don't forget the correct sealant when you're putting it back on, I believe it's called 3M Strip Caulk. Comes in strips on wax paper in a flat mini board game-looking box. You'll see what I'm talking about when you pry the old one off after all the screws are out.
Old Jun 29, 2010 | 01:38 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: t top question?
my last one leaked horribly between the door glass and the t-top. didn't find out until i went through a car wash and got soaked with the windows up...
Frozer!!!
Jan 19, 2024 04:55 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
