Firebird headlight swaps?
Old Jul 17, 2010 | 04:01 AM
dan_needs_a_ws6's Avatar
Car: '91 Firebird
Engine: 305 TBI
Transmission: 4 Speed Auto
Axle/Gears: Stock 2.73's with drums
There's a lot of lighting modifications available for a vast array of cars out there today, including solid red (and other) tails for a Camaro from Kleerz. The Third Gen Firebird has some muscular body lines, and the General agrees by giving it retractable headlights. That's fine and dandy in the daylight, but parking lots are lit and you and everyone else will see those antiquated bug-eyed bulbs protruding from the front end. They're hideous. They're dumb big and open soooo wide. GM finally got that right in '98 when they went to the LT1-era Camaro lamps. Looked way better than the dumb one light, and opened much lower.
My question is, has anyone seen, or done-a headlight mod on a Third Gen Pontiac? I thought many times swapping to a C5 headlight because the benefits of replaceable elements leaves the availability of HID's and they still have a prismatic lens to give it the look that it could have found it's way on a Firebird in.....(1988 for me). But something else came across my mind that may make swaping easier. With obvious modifications needing to be done to the hood and headlight door, would an LS1-era Firebird headlight assembly work? I don't have too much time that lines up with the junk yards so retrieving a set is out of reach right now. So, my hope is that a fellow member can dig out a tape measure and find even more time for a reply. I don't have too much experience with 4th gens to the point where I can recollect certain systems like headlight wiring so if there's a difference in any of that, that would also be pertinent info since I plan on using the whole assembly to establish that low rise opening.
Thanks for reading, and at the least I hope this planted an idea in some people's heads and I see some modern lamps on a 'bird somewhere.
Last edited by dan_needs_a_ws6; Jul 17, 2010 at 04:06 AM. Reason: I ****ed up on it somewhere.
1992 Trans Am
May 10, 2023 07:19 PM
xkingcodex
Feb 12, 2020 07:43 PM
Fronzizzle
Aug 19, 2015 01:36 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
tnrednneck
Aug 13, 2015 08:57 AM
