Quarter panel patch panels '86 IROC, where?
Old Jul 21, 2010 | 03:15 PM
pshelc's Avatar
I need patch panels for both of my rear quarter panels on my '86 IROC. the wheel arches are rusted out and I am hoping I don't have to buy complete quarter panels to fix them. Does anyone know of patch panels are available.
Old Jul 21, 2010 | 03:40 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Re: Quarter panel patch panels '86 IROC, where?
There are patch panels made for just the lower area behind the rear wheel but they only do the bottom 8" of the wheel arch. They're pretty crude panels too. If you've got rust over the top of the wheel arch you're going to end up having to get the full quarter panel skin.
Old Jul 21, 2010 | 03:50 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
http://www.showcars-bodyparts.com/
Old Jul 21, 2010 | 04:15 PM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
What I did was cut what I need from a donor car. For the passenger side I got lucky and bought a full rear quarter for 1.00 on ebay. For the driver I cut one out of a donor car. Check the junkyards. You can use a battery powered sawzall but cut way more (bigger) out than you need so you can trim it to size. I also got the inner fender pieces because mine were bad. That is the cheapest but requires extra work.
KEvin
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Exxon Limited
Aug 9, 2015 08:13 PM
